Got this error so I took the door latch in my hand and moved it all the way to the left a few times (it's a bit stiff) then closed the door and started the cleanning button again and whalla it worked like a charm.
Like everyone said it's because of the door latch.
I live in apartment with a Whirlpool dishwasher and oven. Today was my first day to do automatic clean. After two minutes the "F5SEI" would pop up, then the door would unlock. I repeated this a couple of times. My mind wondered about a water source; perhaps the dishwater. Fortunately, I had a load of dishes ready to go. So I started the dishwasher, then the automatic clean on the oven. Behold! They work together like homies :)
SOURCE: my oven code is F5E1
F5E1 is door latch assembly. One way that may work to unlock is to turn circuit breaker to stove off for few seconds then turn back on and door lock should activate and unlock. If not you are going to have to replace the door lock assembly.
SOURCE: my whirlpool oven door is locked. After cleaning
HI. This will indicate that the door lock mechanism is damaged. follow the procedure below to address further.
If the door is latched:
A. Disconnect power from unit.
B. Check wires and connectors from control to door switch, then from door switch to control. If there is no damage to the wires and all connectors are okay, proceed to step C.
C. Replace door switch.
D. Re-apply power.
E. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
NOTE_ This will, normally, lead to the replacement of the door latch assembly.
SOURCE: I am trying to start my self clean and a minute
Make sure that the door latch is completly locked and then try again. If it is locked and you are getting this code the door latch assembly is bad. The oven sensor would be fine since you get no codes during normal baking. Problem is in door lock system
SOURCE: whirlpool self cleaning oven problem
Hi
Thanks for using FixYa. This error means that
you’ll need to check the door latch/switch and replace the part that has gone
bad. Please do rate the solution
if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
SOURCE: I HAVE A WHIRLPOOL MODEL NUMBER RF368LXKQ RANGE
The F5E1 error codes means that the door light switch OR a switch on the self clean latch has failed. If the oven light comes on and goes off when the door is opened and closed it most likely going to be a switch on the latch thats the problem.
The part numbers are;
DOOR LATCH W10107830
LIGHT SWITCH 3195993
GENE
Before you go working too hard to get
you oven to go into the self clean mode(self destruct)....check out
this tip...
Self
Cleaning Oven Problem
heatman101
Wish I had read this first. I never would have used the self cleaning
option. Thanks for the info!!
