D-Link AirPlus DI-524 Wireless Router Logo
Posted on Nov 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reset password di-624 - D-Link AirPlus DI-524 Wireless Router
Level 3:
  • D-Link Master 7,733 Answers
  • Posted on Nov 11, 2010
D-Link Master
Level 3:
Answers
7733
Questions
0
Helped
1865110
Points
21487
  1. Connect the computer to one of the four LAN ports on the router.
  2. Open a web browser on the computer.
  3. In the address bar of the web browser, type http://192.168.2.1
  4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  5. Click on System Settings under Utilities on the left-hand side of the opened page.
  6. You will see a feature called, "Administrator Password". Type in your current password (default leave blank).
  7. Click "Apply Changes". Your new password is now active.
Note: Do not forget the new password and keep it somewhere safe. If you forget your password, you'll be unable to access your router's settings. If you forget or lose your password, you'll need to "restore to factory default". This will reset the password to its default, as well as erase any and all other settings you may have changed.
I HAVE RESET MY D LINK 624 ROUTER MODEL DI 624 BUT NOW IT IS NOT SECURED. I Had to do this as i forgot password I can't find out how to secure with a new password help help
1. You will have to use the CD that came with the router and go through the "setup Wizard" and establish a new password.
2. contact your ISP ( internet service provider0 and get the information to input into the router to connect properly to the internet.
3. Go to the D-link page and an instruction set for your model router is there to guide you through the setup.
I have problem logging into 192.168.0.1 reset my wireless Di-624 router
The default userID and password for the DI-624 can be one of 3:
1st userID: admin password: (none) leave it blank
2nd userID: User password: (none) leave it blank
3rd userID: admin password: admin
I forgot username and password for my D-link DI- 624 how do I reset ?
At the back of the modem is a reset button. hold that down for 3 seconds.
The Ip will now be 192.168.0.1 and username: admin
No password.
2helpful
We reset the d-link di-624 wireless router and now it will not let us sign back on without the username and password which we do not remember. how do i factory reset the router?
Hi, when you reset your router the password is reset to default, and that default is admin admin. And to reset it, at the rear is a small hole in the hole is a button, remove from the power, and depress the button for a few seconds, then connect the power and try to logon again with your browser using the default settings.
It is also all explained in your user manual link below...
http://www.retrevo.com/support/D-link-DI-624-Wireless-Routers-manual/id/420ci368/t/2/
How can I reconfigure my access point on my DI-624 to 802.11a?
First press reset button for 10 seconds it is in back side of router.
Then connect router to computer with ethernet cable then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then you can see configuration page.
Enable DHCP if you want to get ip from router for your LAN.
Go to wireless enable it .
Then enable wi fi security wep security then enter WEP key it is your password to connect internet .
Then save settings and restart router.
Let me know if you need more assistance.
Thanks.
2answers
D-Link AirPlus Xtreme G DI-624
hold the reset button for 10 seconds then let it sit till the lights stop flashing. then you'll be able to log into the router w/ the default user/password which I believe is admin/password. the ip should be reset to 192.168.1.1 so type http://192.168.1.1 in your browser to log in.
2answers
18helpful
7answers
DI-624 can't login as admin
I was ready to give it up and pitch the thing, but I found this on another board and it worked:
login - admin
password - password (not blank)
2answers
Forgot my password
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624M, DI-624S, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP. Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
2answers
Forgot my password
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
