This solution worked for me, but there could well be different problems which give the same sympoms. My problem was that the microswitch had become worn with use and the interlock slide would no longer cause the switch button to depress but rather it was trying to push the button sideways.
Remove the 2 screws from the rear of the lid and daw the lid off by sliding backwards then upwards.
Remove the 2 torx screws from the top of the front panel that have now been revealed.
Carefully prise the front panel upwards only on the door lock side until the front panel comes forward giving you access to the interlock mechanism.
Remove the 2 torx screws from the front panel holding the actuator in place and remove the interlock mechanism from behind the front panel, disconnecting the two spade connectors and the door release strip.
Carefully prise the two sections of the actuator apart using a small screwdriver in the slots at either end
You will now see two microswitches connected together by a short wire link.these switches are activated by grey plastic slides, one of which slides when the door catch is engaged in the interlock, the other slides when the first one has been actuated and the solenoid actuates. In my case the first one was worn and was jamming the switch instead of pressing it in.
Remove the two microswitches by prising one off its locating pins and lifting it up then prising the other off its locating pins.
There are 2 very small locking tabs on the switch. Prise them out slightly then the switch side can be lifted off.
Slide out the switch button, rotate it through 180 degrees and place back into the switch. This means that there will be a new face in contact with the actuator slide. Hopeully this will provide another few years of good service.
Rebuild by reversing the previouse steps.
Excellent advice allowed me to fix what would otherwise have been an expensive mistake on Ebay. My problem turned out to be the relay switch not being depressed quite far enough, so I packed behind it (having rotated it as suggested here) with a little bit trimmed from the rubber-type insert which covers the door lock assembly where it comes into contact with the front cover of the machine. I had to thin it a little, but it should last and the machine activates every time now rather than hardly ever as before. Very, very pleased!
