SOURCE: how to connect using a LCD monitor, cable box, DVD player
You won't need the VCR, that's only used for a cable box, and since you have one now there is no need. You'll want to connect everything with the better video plugin possible. Composite (red, white, yellow) is the worst, then s-video, then component (red, blue, green), then DVI, then HDMI. That will square your video. Then send all audio signals to the Denon. These cables are usually the red and white cables. OR Plug everything into the Denon to the appropriate input. Then connect the monitor to the video out of the Denon.
SOURCE: Zone 2 problem for AVR 3808
It doesnt down convert to zone 2 via hdmi.... must use analog audio or something else.
SOURCE: Cant Access System Setup on Denon AVR-588
Are you connected with video cables to a tv or "monitor" this is more than likely were the setup is visible for speaker configuration, input assignment etc, most denon receivers work this way so I would suspect you need to re-check the video connection until a set-up picture appears.
SOURCE: Describe your Denon AVR-3805 7.1 Channels RecI
There is a button on the front of the unit under Input its a mode button press this button to select auto that should give you sound
SOURCE: I have a Pioneer PL-S50 turntable that I want to connect
hi you need a
Phono Input Attenuator Line Adapter
the above link is for one on ebay but they are also available through radio shack
