Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
Posted on Oct 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you remove the top off the washing machine to replace the lid switch in a kenmore super capacity 80 series?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 31, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
389
Points
Kenmore series 80, washer runs 30 seconds and cuts off for a while then comes back on and runs 30 seconds and cuts off, takes 4 hours to wash a load.......
Anonymous
Level 3:
  • Master 5,911 Answers
  • Posted on Oct 26, 2010
Anonymous
Master
Level 3:
Answers
5911
Questions
6
Helped
2735878
Points
22413
The following link explains step-by-step how to replace the lid switch on a Kenmore top loader:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions about this repair, please post back and let me know. I hope you find this information helpful.
1helpful
Kenmore 80 series fills with water then doesn't
the lid switch under the control panels bad replace it and it will again wash,they just unsnap out of the top of the cabinet after you remove the control panel
How do I replace lid switch in a Sears Kenmore 80 series, model 1
The following link explains step-by-step how to replace a lid switch on a Kenmore top loader:
If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: Kenmore is manufactured by Whirlpool so these instructions will apply.
2helpful
Kenmore washers, heavy duty 80 series, no spin
Hello, Your problem is going to be with your lid switch, this is located normally either in the control panel or about half way down on the right side under the lid. This is a safety feature to stop you opening the lid while the machine is in a high spin. Once you have located the switch trace the wires back to the wire harness in the control panel. Disconnect the lid switch from the wire harness and with an ohms meter check for condinuity on pin 1 & 3 (the 2 outside pins not the middle this is a ground) You should find you have no condinuity and should replace this switch. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
1helpful
Kenmore Series 80 washing machine won't drain after wash cycle. The machine just stops.
Check the lid switch under the edge of the top where the lid closes. When you are about 1 inch from closing the lid you should here a little click sound. That is the switch closing. I fyou do not here the click then the switch is bad.
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
1helpful
Rinse cycle do not disengaged
does it drain?did you check the lid switch?
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
1helpful
Won't spin or drain
Check to make sure your lid switch is working.
1helpful
I also need the answer...
Verify Lid switch ..... A solved rating is great motivation to continue giving priceless advise........
Alexander
vince
