SOURCE: Cannot set time @ date
(A=LIGHT,B=MODE,C=START,D=RESET)
1.How to use the luminescence Any time indication,Press A the Luminescence will last for 3 seconds.
2.How to view date? Standar time indication, press C "month/ date" indication.
3.How to switch 12/24 hour systems In the normal mode, press B twice and press D twice ,then hold C until 24 hour system is actuated, then press B for recovering.
4.How to check alarm ring and alarm time? Standard time indication,press D alarm time indication.
5.How to set alarm time? Standard time indication,Press B twice. The hour area flickers,press C to set the hour. After setting hour ,press D,the minute area flickers, press C to set the minute. Last press B for recovering.
6.How to set alarm ring? In standard time indication mode ,Hold D then Press C this will toggle alarm symbol on & Off.
7.How to set Hourly Chime? In standard time indicationmode, Hold D then Press B DAY OF WEEK area toggle on and off.
8.How to use stopwatch(1/100 seconds) Press B,then Oress C for 1 timing; Press D for multiple timings. Press D once more to continue operation after multiple timing. Press D for 1 timing; press C once and press Dtwice for multiple timing. (1)Max range of the stopwatch is 23 hours 59 minutes 59 seconds. (2)When timing within 30 minutes, the watch indicates: minute/second/1/100 second (3)When timing beyond 30 minutes, the watch indicates:hour/minute/second
9.How to adjust time, date,day of week (1)Standard time indication,press B twice ,the second area flickers, pressC to adjust second. (2)Then press D the Minute area flickers,Press C to adjust minute. (3)Press D the hour flickers, press C to adjust hour. (4)Press D the Date flickers, press C to adjust date. (5)Press D the month area flickers, press C for adjustment. (6)Press D the Day of Week area flickers, press C for adjustment. Then press B for recovering.
SOURCE: Ohsen Watch Manual (AD0721).
Press the D button then press the C button and
you will see the alarm indicator swith to a large
bell. Hope this helps.
