SONY CYBERSHOT DSC - H3 DIGITAL CAMERA FLASH PROBLEM
Hi Jim,
Have you tried resetting all settings on the camera? On a Sony camera, it is called "initialize". The initialize setting is found by going to the menu, and tabbing down until you find an option called either "reset settings" or "initialize settings" and then confirm it.
Many times that will fix the issue, in case something has either been enabled/disabled on accident, or the software is sticking (which happens from time to time)
Hi,Kimani from Nairobi here.
Am having exactly the same problem with my sony cyber shot DSC-W30 digital camera(my flash wont work and E:91:01 keeps flickering).
I've tried refreshing the settings by initializing the setup again and again as per the owner's manual but nothing doing.Need i say i use it everyday for about a year now but this error code started showing in mid May.I now can't shoot photos in dark areas and at night with good results.Pls help.
