20 Most Recent Sony Cybershot DSC-H3 Digital Camera Questions & Answers
Go to this Internet address:
If this is a response to an earlier query, it should have been appended to that query, not posted as a separate comment.
8/3/2017 8:02:34 AM • Sony Cybershot... • Answered on Aug 03, 2017
0answers
Camera want flash sony dsc-h3
If it flashes when you take any photo then you have the flash set to manual override for each shot or you're just shooting in areas too dark for any photos without the flash. Check your flash settings or try a factory default reset from the camera's menu options.
1/5/2015 2:55:24 PM • Sony Cybershot... • Answered on Jan 05, 2015
I cannot find sports mode on camera
It's on the "Mode dial" the big wheel on the right up-hand side of your camera. Find the symbol with a person running. Or you can read the manual in the following link. It's on page 15. https://docs.sony.com/release/DSCH3.pdf Hope this helps.
12/10/2014 4:31:18 AM • Sony Cybershot... • Answered on Dec 10, 2014
0answers
2answers
How to recover formatted files in sony dsc-h3
The best solution I have known for recovering lost files due to formatted discs or cards has been Sandisk's software called RescuePro. It is well known to recover files that have been formatted once, twice, or more. To me, it's worth the 40 bucks versus never getting that moment back. Here's the link: http://www.sandisk.com/products/software-and-services/data-recovery
12/11/2013 2:42:35 AM • Sony Cybershot... • Answered on Dec 11, 2013
3answers
Pictures still blurry
Instead of green auto mode set to P mode and chagne the flash setting to non auto.If flash is is in auto mode flash will not fire and picture will be blurry.So your flash must fire every time (and it must not be decided by camera's auto flash mode).
I am sure this will solve your settings.
Please rate if satisfied.
10/5/2013 6:34:02 AM • Sony Cybershot... • Answered on Oct 05, 2013
2answers
Im looking for user manual of SONY DSC-H3
I'm glad to provide the Instruction Manual of the Camera. Please click hear to download the Instruction Manual.
Click hear to download the handbook.
Please let me know if you require further assistance.
10/5/2013 6:21:28 AM • Sony Cybershot... • Answered on Oct 05, 2013
While on auto mode LCD displays e:62:02 on the
E: 62:12 is an indication that a malfunction has occurred in the camera. Reset the Camera to resolve this If the issue persists it wil need repair, and is good to have a service manual for it you can get one from the below link:http://goo.gl/xVFQGygood luck
9/3/2013 12:24:01 PM • Sony Cybershot... • Answered on Sep 03, 2013
My camera dsc-h3 displays e:62:12
9/3/2013 12:21:31 PM • Sony Cybershot... • Answered on Sep 03, 2013
manual
How to tighten the loose mode button?
due to hard press. replace the button magnet
4/26/2013 2:31:59 PM • Sony Cybershot... • Answered on Apr 26, 2013
Macro Invalid :(
hit your menu button. go down to setup. in the setup menu there is a tab for "Conversion Lens". make sure it is not set to "Close Up". i have mine set to off because i am not using any conversion lens.
4/11/2013 7:27:35 PM • Sony Cybershot... • Answered on Apr 11, 2013
DSC-H3 does not focus a subject properly as compare to the begining. The picture is blurred in autofucus mode as well.
Dear Bobby, Your concerns about the mechanical/physical integrity of the components may be valid. However, it could be a simpler, and less stressful problem altogether. I recommend, you get hold of a micro-fibre cloth. And, blow at the lens, and clean it in circular directions. As your camera appears to be quite old, I recommend cleaning the lens, as it could have gathered dirt, or dust. There is no focus sensor, as such. There is however an autofocus motor. Which could be the problem. However, let's take it one step at a time. Hope I was of assistance.Regards,Rebel K.
2/21/2013 2:52:24 PM • Sony Cybershot... • Answered on Feb 21, 2013
I need a different way to charge my sony cybershot DSC-H3 digital camera
The DSC-H3 does not contain any charging circuitry. You could hook it up to a nuclear reactor and it won't charge the battery. You need to use a separate charger, such as this one.
6/29/2012 3:15:25 AM • Sony Cybershot... • Answered on Jun 29, 2012
It keeps saying my sony
Press the "Home" button, go to "Settings" (last menu item at right), then "Main Settings", and use the "Initialize" button.
And also;
Macro is not available in landscape mode, twilight mode or fireworks mode, if you try to use macro in any of those modes it will say invalid macro.
5/10/2012 10:01:08 AM • Sony Cybershot... • Answered on May 10, 2012
How to recover formatted pictures
Sadly formatted pictures are permanently deleted from the device, unless a copy of the photo exists on SD card the data of the photo has been erased :(
1/26/2012 7:58:38 AM • Sony Cybershot... • Answered on Jan 26, 2012
I have a sony chyber-shot dsc-h3 fix and the flash isn't working? It opens when like it's going to flash but it doesn't flash.
Hi the flashing unit is faulty,it must be replace with a new one
1/13/2012 2:54:22 PM • Sony Cybershot... • Answered on Jan 13, 2012
Sony Cybershot DSC-H3 Digital Camera Logo
101 questions posted
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
pictures still blurry
  • Cameras
