Pride Jazzy 1103 Ultra Standard Power Chair  Logo
Posted on Oct 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My mom just had her battery changed and got a new charger. we plug it in and try charging it but it wont hold charge?
A Miller
Level 3:
  • Master 8,404 Answers
  • Posted on Oct 15, 2010
A Miller
Master
Level 3:
Answers
8404
Questions
Helped
2053293
Points
24677
If the batteries will not hold the charge ... it is time for replacement batteries.
No flashing LEDs. Joystick and charger indicate full charge.
Time to replace battery - not taking a charge properly.
Sidekick battery not charging
That sounds to be a charger plug going bad (yes, the one from the device)
Try an electronics service to replace it for you .
Its plug in but battery wont charge
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
3answers
My battery died, tryed to charge and it wouldnt thought it was the charger so bought a new one and it still wont do anything. No charge no lights no boot
pull the battery out and unplug from power, Hold the power button down for 30 seconds (really hold it down for 30 seconds :-D ). Put the battery back in and reconnect charger.
My sanyo pm 8200 wont hold charge!
Since the battery and charger are new and yet it does not still hold charge.
Have put the battery in another similar phone and try to charge with your charger to see if it will hold charge? if you have.
It means the charging port of your phone is bad and you will need to replace it.
The charger is not charging the battery in anyway because the charging port is bad, so just change your charging port, your phone will now hold charge.
Take care.
2answers
My phone wont charge.... i have bought a new battery, charged it for 24 hours, and it still wont charge. even when it does charge it wont keep the charge for more than a day. why wont it charge. plzzzz...
It could be the charger itself that has the issue. If you have another charger try that. If you have done this and it still won't hold a charge I would contact your service provider they will try to trouble shoot issue but more than likely will get you to send phone in through warranty if your still eligible. If not eligible for warranty and don't have insurance ask about upgrade options. Hope this helped.
3helpful
3answers
Cannot charge LG EnV2 VX91000 phone
The issue is the charger port on the ENV2 breaks fairly easily.Thefirst step is to contact your carrier to see if it is coveredunderwarranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.You can get an external battery charger to charger the batteryseparatefrom phone. cost about 25 dollars. Check out the following linkforones that are available on ebay. A extra battery is a good idea aswell so you can have one charging at all times.
LG VX9100 ENV2 External Battery Chargers
Hope that helps
Psp sont charge.. new battery
try a new charger if that dosnt work take it into a shop that sells them and try ask them if they no wat to do
Sgh p310 wont charge
Hi!
Please check your charging port if the pins are still OK. Please also try a new charger. Perhaps your charger is already defective.
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Unable to Charge
either reflash the phone or have the main-board replaced
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
