SOURCE: i need the schematic for the crown amplifier
These are available for purchase from Crown. Generally they are not available on the web. Is there a specific problem that you are having?
Dan
SOURCE: fan don't work when power is turn on
hello try and get another fan strip the wires and where the fan is connected place there. and turn if the fan spins the you need a new fan if it don't spin then the fan fuse may have blown
regards
shaun
SOURCE: Crown Xti 2000, signal to both channels, no sound
common problem with xti series... all the amp needs is a soft ware update contact crown and they can sort it for you... you dont have to send the amp back to them. it was a verry common fault with all the early xti amps..
