While trying to get images from the camera to computer it appears that it pulled everything from the camera (no files are left on the camera) and stored it in a file on the computer. I can identify the file on the computer but the production software will not allow me to load/open the file(s) to create a dvd. Please Help.
Dave
Video supported by your camcoder
Video:
MPEG-2-PS /
Audio: AC3.
Solution :
Using Power Director:
1. Copy MOD file from camera to chosen directory on Hard drive.
2. Import MOD file - File, Import Media files. (MOD not listed in files of type drop down box but just chose file anyway)
3. Edit project then save project as pds file.
4. You can then either produce movie in Power Director by chosing following:
Disk if required to play in DVD.
File mpeg2 if need to open in other authoring program
Streaming if needed for Internet
Everio if need to play back on Camera (MOD)
OR
Open saved project in Cyberlink Producer.
At start up screen select disk format (I chose SVCD & CDRW but your choice might be different)
At next screen Import Video files.
Chose previously saved *.pds file.
Edit SVCD structure as required, then at next screen chose burn options.
also you can use
JVC CU-VD20 'PAL' Share Station Direct DVD Burner - for Everio Camcorders
About share station direct dvd burner
With the JVC CU-VD20 'PAL' Everio Share Station - Direct DVD Burning without a PC you
can connect directly to an optional Everio Share Station DVD Burner
CU-VD20 via USB2.0 and you can burn a full-sized DVD-Video disc without
a PC. Burning operations are controlled from the Everio itself or by
its remote.
Link to buy share station direct dvd burner
http://www.samstores.com/details.asp?ProdID=8866
_____________________________________________________
Thanks for using fixya technical support.You have a great day
What kind of file is stored on computer, what extension (eg *.avi)
Cannot locate MOD file on camera. Camera reports "no files"
Dave
What I thought was on the computer I now cannot find.
Dave
