Ovens Logo
Anonymous Posted on Oct 08, 2010
Sears kenmore electric oven not turning on. stovetop works. oven light comes on
  • 3 more comments
  • Anonymous Oct 08, 2010
    3 years and warranty expired
    3 year old sears kenmore. oven does not turn on. stovetop works fine. oven light is on.
    yes oven light is on and range works fine
    would it be on its own circuit breaker. I mean just the oven doesnt work. Everything else does
    i reset the oven by plugging it in, waiting, and then plugged it back in. both oven and broiler not coming on still
Jose Cada
Level 3:
  • Master 3,530 Answers
  • Posted on Oct 09, 2010
Jose Cada
Master
Level 3:
Answers
3530
Questions
Helped
965499
Points
9839
Two things:
  1. Bad heating element. Click on this link on how to do a heating element testing.
  2. Bad timer/clock. It needs 240 volts to heat the oven, if that clock/timer control is only sending 110 volts to it, then you would need a new clock/timer assembly. Please click on the link on how to do timer/clock testing.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Anonymous
Level 3:
Genius:
  • Master 1,478 Answers
  • Posted on Oct 08, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1478
Questions
0
Helped
287967
Points
4140
Check to see if power is getting to the range/oven. Does anything turn on--even a light? If not, check for a blown fuse or tripped circuit breaker.
Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
Take care.
    I will advice you reset your oven, try unplug and plug back.
Anonymous
Level 3:
  • Master 881 Answers
Anonymous
Master
Level 3:
Answers
881
Questions
Helped
420813
Points
2851
How long have you had this oven?
I can't use my oven it keeps turning off and my oven is beeping and the problem light is flashing how can I fix this so I can use my oven
Kenmore electric oven keeps shutting off.... ' Sears PartsDirect
www.searspartsdirect.com > Ask an Expert
Oct 15, 2010 - Kenmore electric oven keeps shutting off. ... Can't locate your model number? Use ... hi, i purchased and replaced my etc (#316455420) for kenmore electric range model # 790.9011.2010. i was ... How to use the site (3:58) ...
Frigidaire oven Bake functions randomly beep and shut off ...
Dec 25, 2015 • Ovens
Moved Kenmore electric oven (2 yrs old) and now neither the oven or stovetop heat up. The clock is set.
This may sound silly, but go check your circuit breaker and flip it completely off and then back on. Sometimes it does not completely trip and your clock only needs 120 volts to work which you have, but the heating coils need 240 volts. If you have an older house that has a fuse panel instead of circuit breakers you could have a blown fuse.
Oven doesn't heat up
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
1helpful
Where is the reset button on kenmore c970-440928? oven and stove top dont work at all.
i need to know where the reset botten is on a kenmoe electric stovetop
Kenmore electric oven will not heat, broiler and stove work fine
I also have the exact same problem, is ther a possible fix-it-yourself solution for this???????????? if not what should a repair cost?????
2answers
How to light oven with electric power off?
Sorry, but this oven will not work without electricity. Looks like stovetop suppers for a few days. Hope this helps!
Jan 28, 2009 • Ovens
Older Ceramatop GM Frigidaire oven stopped working-stovetop works
If it has a timer of any description, make sure it is set to manual, refer to your instruction book.
Stovetop locked
look closely at the control panel there will be abutton marked, control lock, yuoll need to hold it down for 3 -5 secs, its achild lock feature, youre manual will explain if you still have it
Kenmore oven 362.75275690 won't fire...has new ignitor
if you get 120 volts to the ignitor, then the ignitor will glow ,if not you have a bad ignitor. the valve should have continuity through the the 2 connections.. its poosible to have 110v to ground at ignitor, the only way you get 110v you need to check power across the 2 wires to the ignitor( not to ground), and this will not happen with a bad safety vavle
Top Blodgett Ovens Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
