Computers & Internet Logo
Posted on May 29, 2008
Gigabyte GA8ST800 Motherboard
I have a gigabyte GA8ST800 motherboard with on board graphics and soundcard. Do you know where I can find the drivers for both of these devices?
The manu. name ASROCK P4i45GL also appears on my motherboard.
Will asrock drivers work?
Thank you
Jeff Gillis
Level 1:
Problem Solver:
  • Contributor 20 Answers
  • Posted on May 30, 2008
Jeff Gillis
Contributor
Level 1:
Problem Solver:
Answers
20
Questions
0
Helped
6212
Points
59
The Gigabyte website has drivers for the onboard soundcard available, but according to the specs for the Gigabyte GA8ST800 Motherboard there is not built in video card on that model so I'm guessing that is not what you have. See the links below as both have specifications and pictures of their boards that should help clear up which board you have. .
The ASROCK P4i45GL does have the Integrated Intel Extreme Graphics adapter built in, do if that is the MB you have, you should be able to use the drivers linked below.
Drivers/Documentation for the Gigabyte GA8ST800
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1681
Drivers/Documentation for ASROCK P4i45GL
http://www.asrock.com/mb/download.asp?Model=P4i45GL%20R3.0&s=478
Cheers
No display in gigabyte g31m-es2l
Hello try to download the manual here:
http://www.gigabyte.com/products/product-page.aspx?pid=3485#manual
You need adobe reader, to read the content.
Check all the power connections again, and the power supply for fault.
It may be there is nothing wrong with your motherboard. Often time, on-board graphics will be disabled with a discrete graphic card is installed. Check your motherboard manual to see if this is the case. You may also be able to find a setting in your system BIOS that allows you to enable the on-board graphics even if a discrete graphics card is installed.
Try also to reset the bios, by removing the cmos battery, and insert it again.
You can also try to add a graphic card, on the mainboard, in the blue PCI Express x16 slot.
Just make sure you have the driver, for your windows system.
Good luck
I have an intel core 2 duo E4400 CPU (800Mhz FSB, 2GHz clock speed) with the gigabyte motherboard GA-G41MT-D3 but the motherboard seems to insist on running the CPU at a clock speed of 1.2GHz. The BIOS...
hello there i am also using a intel Core 2 duo that i have over clocked to 3.3GHz reason i am bring that up is i had to mod the mother board i would say lets start there if you need help with modding the Gigabyte let me know. as its going to be a long email =)
Recommend me a good gigabyte mother board.
Without anymore information, what your wanting to build the computer to actually do, Gaming etc...
Have a look at the :
Gigabyte GA-P41T-ES3G G41 Socket 775 8 Channel Audio ATX Motherboard
Hello I have problem with my gigabyte GA-EG45M-UD2H
you can down load the driverse from this website http://www.gigabyte.us/Support/Motherboard/Driver_List.aspx
you will need to know the model of the mother board it is usally on th eboard.
3helpful
I have a Gigabyte GA-K8RS482M motherboard, but i can't find the type of the soundcard integrated with it... can sbdy help me with that??!
Just go through the following link and then you will be able to download the correct drivers for *********** boards
http://www.gigabyte.com.tw/Products/Motherboard/Default.aspx
2helpful
Gigabyte GA 81845 GVM 775 Soundcard drivers
Hi try this link:-
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1930
It has all the drivers you need for your motherboard.
Hope this helps.
Soundcard driver for 865 chipset
Go To Gigabytes Website Support Sectiona and put your model number of your motherboard in and it brings up the drivers - find the right one , download and install! Easy!
If you dont know your model number , its printed on the board itself
or use software such as everest home edition (free) or belarc advisor (also free)
http://www.gigabyte.com.tw/Support/Motherboard/BIOS_List.aspx
2answers
AGP card support
Hi, Unfortunately no AGP slot nor PCI-E. The Gigabyte GA-8I845GV motherboard has only 3 Expansion Slots and all of the are PCI (33MHz & PCI 2.2 compliantt). From their website, here's an image of the motherboard http://www.giga-byte.com.tw/FileList/Image/motherboard_productimage_ga-8i845gv_big.jpg It has a built-in IntelĀ® Extreme Graphics Engine (845GV chipset) for video with max of 128 mb shared memory. Should you wish to install an add-on 3rd party PCI video card, Inno3D FX5500 256ddr PCI slot tv-dvi are still available (at least in my location) for an equivalent of about 3.5K INR (80USD+). Hope this gives you an idea. Good luck and kind regards.
2answers
What graphics card this motherboard will support
Gigabyte did not put a special graphics slot (AGP, PCIe etc) on this corporate series board. It has good internal graphics support. If you would like to run two monitors, it appears that one choice is the CHAINTECH P-FX20 256MB Geforce FX5200 256MB 128-bit DDR PCI Video Card, based upon user reviews at NewEgg. You may need help getting both graphics adapters to operate together. Typically, there is a jumper on the card that disables "Primary VGA" mode. Your OS should boot using the on-board adapter and then you can tell the OS that it should "Extend the Desktop" to the second (PCI) adapter. Your results may vary.
Grand Canyon Tech
Grand Canyon Tech
