Its not the tv the tv, the tv is just a monitor the dvd is suspect as the tuner may be ...old, damaged ect. and last the antenna a new ant is not required for hd however you are not saying you want to get hd you want to get rid of your satellite receiver, HDMI is the best signal for video you can use, however the source is the most important thing if it sucks or is not to top quality, like the HDMI circuit then you will get a reduced picture quality. the dvd recorder? is suspect as is the antenna you are using, 75 ohm coax will not produce good results.
I purchased the W4207 from Best Buy as well. I previously used direct tv tuner. I recently moved to development that does not allow satellite. However, they offer free cable. Is there a tuner that can be purchased for TV without renting cable converter box?
