Pcb is dad
If it's over filled it won't spin.
The fault is most likely either with the water level sensor or with the filling solenoid. Both are cheap parts but note the caveat of "most likely". If you buy and fit the parts with no improvement you cannot return them, but a Bosch repair agent can try them and remove them if they're not the cause. The worst case is a failed pcb, but repairing your machine will still be cheaper than replacing it. Barring occasional faults, Bosch washing machines last longer than average.
