Have you tride updating wifi drivers some times this helps get from https://driverscollection.com/?H=D620&By=eMachines and remember always install new software or drivers as Administrator.
SOURCE: Wireless driver problem
first check in the device manager if you have the correct driver installed
second, make sure that the wireless device is enabled (for acer normally there is a switch infront)
SOURCE: making my emachines D620 wireless
when you installed the driver for the usb did you select your usb device model ? some drivers are written for usb devices AND for wireless cards (=pcmcia) and at the begining of the instalation they ask: please tell me do you have usb or pcmcia ? or they might ask you (for example) to select the right model.
now if you have "usb" but you selected "wireless card" then at the end it will try to locate a wireless card.
if this is not the case then probably your usb is not working ok - you should try it on another laptop (or pc) and then have it changed at the shop you bought it...
the driver does not recognize the device because
