SOURCE: Windows Vista on intel d865gbf
I made some of those work by installing windows xp drivers, i dont remember which ones.
try this link.. http://www.userdrivers.com/Motherboard/Intel-D101GGC-Desktop-Board/download/
SOURCE: Intel DG965RY Motherboard sound problem
which operating system are you using? follow this link http://downloadcenter.intel.com type in your motherboard number DG965RY and then select support from overhead menu
SOURCE: driver for mercury 945gc motherboard
Check the model number on your board. The only thing close to what you have listed here is the pi945gcm. If that is what it is then here is the link for your drivers.
http://www.mercury-pc.com/product-drivers.php?productid=751
SOURCE: My Intel D102GGC and Mercury 915GLV motherboard not wake up
Is this new ram or have you used it in this machine previously?
A couple of things can cause what you describe, one of them being the wrong voltage of ram. This page contains the list of memory that your system can use, check the part number on your current ram in google to find out what voltage it runs at (the recommended voltage for your board is 1.8v).
Other than that you may want to do a CMOS reset by changing the jumper block (should be described in your mobo manual), powering the machine on briefly, power it down (unplug) and return the jumper to it's original location. Now try to post the machine.
