I had the same problem with the same equipment and I found this on the web. It worked well for me.
* Remove the base unit's phone from its cradle.
* Unplug the power from the base unit.
* press and hold the FIND button on the base unit, then, while continuing to hold down the FIND button, plug in power again. The CHARGE light should then be flashing. You can release the FIND button.
* press and hold the # (pound) key on the accessory phone you are attempting to register to the base unit and hold this phone OVER and NEAR the cradle/charging prongs until the phone goes through the registration process. (again, don't set the accessory phone in the unit, but just hold it near the unit).
thank you so much for posting this! we've been frustrated for months trying to find out how to register these accessory handsets. your method worked right away.
It worked!!! Thank you so much!
Right on. After hours of frustrating attempts this worked the first time. Unuden should update their owens manuals.
This process worked for me in registering my new DCX150 accessory phone with my DECT1560 base. My issue was 100% as described and this solution worked as described on the first attempt this day of 9/17/2011. I purchased this accessory phone from Walmart.com using their free shipping method site to store. Thanks much.
I just purchased a new DCX150 had the same problem. This process worked for me after using the Uniden manuals from their web site. Thanks.
