20 Most Recent
Uniden D1680 Cordless Phone Questions & Answers
Uniden DECT6.0 Model D1680
Problem: Need to change recorded message ,cant get past Security Code_ a 2 digit pin .Forgot what is was..
The only time the Security Code is used is to effect
Remote Access, ie, "call home and manage your
answering machine messages remotely" by pressing
the code numbers while the Greeting is being said....
The Security Code is set on the D1680 from the handset
by this procedure:
press [menu]
scroll to "Ans. Setup"
press [select]
scroll to "Security Code"
press [select]
the code will be displayed, first digit blinking
(enter a new digit if you want to change it )
the code will be displayed, second digit blinking
press [select] (chirp) press [END}
All of the Answering Machine System functions can
be managed remotely, and voice menus are provided
to guide you in these operations.
Entering the model number found on a small sticker under
the battery in the handset at
www.manualslib.com will
fetch a free copy of the User's Manual in case the original
has been misplaced.
Why can't I change code?
With the phone in standby, open the menu; select Ans. Setup, then select Security Code. Use the number keypad to enter a two-digit security code (01 to 99). Press Menu/select when you're finished.
Uniden D1680 will not ring
you have silent mode turned on try umplug the base uniy for about 30 sec and plug back in or go to instructions book
Message light keeps blinking
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
