Cameras Logo
Posted on Sep 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am using a Nikon D200. When using flash I can't raise the shutter speed any higher than 1/250. It seems to be locked there and I don't know how unlock it. Please help.
Anonymous
Level 3:
Brigadier General:
  • Master 3,006 Answers
  • Posted on Sep 03, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
3006
Questions
0
Helped
960090
Points
10121
That's entirely correct. 1/250th is the fastest shutter speed you can use when using flash. Many other cameras can still only use 1/60th or 1/125. It's all to do with the two curtain nature of an SLR shutter: when you release the shutter, one curtain withdraws across the frame to expose and then a second one follows behind to shut off the light source. For exposures of 1/250 or slower on your camera, the second curtain does not start to travel across until the first one has fully opened, so you have a fully open exposure frame allowing the flash to reach every part of the sensor. At faster speeds, the second curtain sets off before the first one has finished and at the highest speeds it's so close behind the first that only a narrow **** is open to the incoming light as the shutter curtains pass across the sensor. If you fire the flash at these speeds the shadow of the first or second (or both) curtains will appear on the sensor and the picture will look like a narrow horizontal band, or if using fill in flash, it will look like a bright band across the picture.
It's immaterial though as the normal exposure rules don't apply with flash: the flash duration is typically anywhere from 1/4000th to 1/50000th and in that exposure time it outputs sufficient light onto the subject to enable a photo to be captured. As the flash is the dominant light source, the ambient light captured when the shutter is open for 1/250th is insignificant unless you're making a daylight exposure and using the flash for fill in purposes.
There are some specialist SLR and flash combos which will allow the full range of shutter speeds, but they do so by firing the flash multiple times very rapidly to ensure that there is flash light present effectively continuously as the narrow exposure **** passes across the sensor.
Compact cameras have shutters which work differently and which fully expose the sensor at all shutter speeds, so in that respect they can have a far more flexible flash exposure system. Unfortunately, they ruin it by having pathetically weak built-in flashes which are only good for very short distances.
1helpful
2answers
I have a Nikon d200 and need to take sports photos in a basketball court The sport is very fast moving. What should I set the camera to. Lately the photos are dark and or blurry
You want the fastest shutter speed you can get and the largest aperture possible.
If you're close enough and it's allowed, use the flash. The flash will freeze the action. However, it's likely to give you a dark background instead of a blurry background.
If not, use the Aperture Priority mode. Open the lens to its maximum aperture (smallest f/number). This will give you the fastest shutter speed for the existing lighting conditions. The fast shutter speed will freeze the action and the large aperture will blur the background, though the amount of freezing may be limited if the lighting is relatively dark, as in a high school gym.
Be aware that if you're shooting indoors you're going up against the laws of physics. The human eye can adapt much better than any camera. A high school gym will appear light enough once you've been inside for a few minutes, but it is much, much darker than a bright day outdoors.
My sb-200 flash won't work with my d200
Go to menu then shooting and turn on ttl
2answers
D300 long shutter delay
are you using mirror lock-up or live-view feature?
Shutters lags for 1-2 seconds then takes picture. Nikon D200. Thanks L.C
Does it still lag with the use of the flash?
Not sure this is a camera issue because I dont know the level of expertise you have with the functions of your camera or your knowledge of photography. So no insult intended...If your in low light or indoors, try using the flash or change to a higher ISO.
Does this help?
1helpful
I am unable to get the shutter speed above 1/60 on our D200. It was working fine. Is there some setting in the camera that would limit shutter speed even with flash?
The flash is probably what's limiting your shutter speed. All cameras have a maximum shutter speed that syncronizes with the flash.
Prob with exposure analog...
i could tell you how to fix it but it would probably cost more than a new camera. just buy a new one.
Beginner need some help please
There's absolutely nothing wrong with your camera. You simply need to learn about the basics. Read on the web about exposure, shutter speed, aperture, and how they affect each other. If your shots are blurry, the reason is that the shutter speed was too low.
How can you know when the shutter speed is too low?
- Use a tripod (the VR of the lens must be off in this case)
- Or, for hand-held shots, use shutter priority mode and set a speed as fast as the focal length of the lens. - i.e. for focal length of 100mm, a handheld shot must be taken at 1/100 sec or faster. Of course, the light might not be available for such a faster speed. The VR also gives you some latitude, but it's not panacea.
Additionally, DSLR cameras (esp. if you shoot RAW) produce images that are less saturated and contrasty compared to the blown out photos produced by point and shoot cameras.
You have a remarkable camera, just take your time and learn the basics of photography.
3answers
D200
what is the actual proablem?
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
