Estate TAWS800JQ Top Load Washer Logo
Anonymous Posted on Aug 28, 2010
Washer filled with water then quite doing everything. Just sits Idle. Does that make it main control problem or lid switch?
Anonymous
Level 3:
President:
  • Master 1,430 Answers
  • Posted on Aug 28, 2010
Anonymous
Master
Level 3:
President:
Answers
1430
Questions
Helped
308376
Points
4820
More likely the lid switch. Here is a link that should help http://appliancehelponline.com/toplidswitchvideo.html
Testimonial: "Lid switch was it. Plastic case seperated was only problem. Thanx"
Water starts to pass through but then stops and error alarms start
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
The water starts to come through then just stops and then alarms go off
My maytag epicz will run water and then just stop it lock and later get code f33
Whirlpool 1000 w100 stops after filling with water
Not doing cycles
see the diagram attached.
Agitator continuously on
see the diagram
Agitator starts wont quit
see the diagram
Washer stops at rinse cycle and give the ul code F1
1helpful
Machine fills but wont do anything else
try the Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse. or your motor coupling could have broken!
2helpful
2answers
Washer wont work.
I FOUND BROKEN BELT . HOW DO I CHANGE IT ?
Top Estate Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
