My dishwasher is not cleaning at all. It was working, but now is not. We had trouble with our hot water and installed a water heater but the dishwasher is still not working.
We had a plumber fix the water pressure problem in the sink but the dishwasher is still not working. He said the heating unit looks like it is getting to hot.
When I turn it on, I do not hear the water running like I used to. Is there anything I can try before paying a small fortune for the repair guy?
Possible problem is that the chopper/cutter filter is plugged. This prevents water circulation and therefor no water is available for cleaning.
Solution:
Remove the dish baskets.
Remove the bottom cleaning arm - Rotate the centre post and the arm can then be removed.
Remove the conduit that feeds the upper arm(s) - Remove screws, one at the back and one at the top. Rotate the whole assembly 45 deg right and lift off of the centre post.
Remove 4 screws in the plastic assembly and lift it off of the centre.
Remove 1 screw at left front (Under assembly just removed). Lift off the plastic cap which covers the cutter/chopper. Remove the chopper. It is on a spring loaded pin. Pull the cutter foreword while lifting the filter disc straight up. Thoroughly clean the filter disc - a knife will be req'd to scrape in clean.
Reassemble in reverse to the disassembly steps.
Anyone have any hints on reassembling the cutter/chopper from Solution 2?
We can't get it back in.
Check the water inlet valve to see if it is getting voltage to it if it is replace the water inlet valve,,,,,,,also check to see that the house water valve for the dishwasher is turned on so water can come into the dishwasher
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Any suggestions on how to get the cutter chopper from Solution #2 back in? "Remove the chopper. It is on a spring loaded pin. Pull the cutter foreword while lifting the filter disc straight up. " We just can't get it back in.
