When the power seat lift lowers down, there is usually a bracket that pushes a button under the seat that tells the motor the seat is lowered and the power chair is safe to operate. Sometimes the bracket can get bent and the button does not get pressed when the seat goes down. Check under the seat around the seat post for the button and make sure the bracket is connecting to it. Carefully bend it back into place if it is not hitting the button properly. If the bracket came off, it will need to be replaced.
That switch on a lot of chairs is an external switch but on this chair the limit switches are micro switches on the motor drive .. remove the rubber cover on the motor drive .. 2 or 3 micro switches .. a small screwdriver will loosen the switches and then they have to be adjusted ... a little complicated to find which switch controls which function .. keep trying ..
