Electrolux Over-the-Range Microwave Logo
Shirley Megason Posted on Aug 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frigidaire (made by Electrolux Home Products) over range, stainless 1000W microwave:: Model# FMV158FMB:: was using microwave. heard a loud buzzing noise and microwave went out. will not come on. either at or split second after loud buzzing sound, all lights & electrical at my house flickered so don't know if there was a brown out or what. it seemed to all happen at the same time. Have checked the breaker & it is NOT thrown. Plugged it into another electrical plug using a heavy duty electrical cord & it still does not come on - no light on the display; nothing.
Anonymous
Level 3:
  • Electrolux Master 43,501 Answers
  • Posted on Aug 19, 2010
Anonymous
Electrolux Master
Level 3:
Answers
43501
Questions
0
Helped
10845463
Points
101584
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
How do you turn the turntable on a frigidare microwave model fgmv155ctf on and off
Image Disclaimer
AUTHORIZED DEALER Frigidaire Gallery Series
FGMV155CTF
30 Inch Over the Range Microwave Convection Option Sensor Cooking SpaceWise® Rack
4.4 Average rating of
73 reviews
color: smudge proof stainless steel
Smudge Proof Black Stainless Steel FGMV155CTD
$569.00
Smudge Proof Stainless Steel FGMV155CTF
$519.00
product highlights
Optional Built-In Trim Kit Convection Sensor Cook quick specs
Dimensions
Width: 29 7/8 Inch
Depth: 15 7/16 Inch
Height: 16 13/32 Inch
Features
Capacity: 1.5 Cu. Ft.
Cooking Watts: 900
View more Frigidaire 4 Piece Kitchen Appliances Package
Get the bundle for just $3,44800View the Bundle Recommended Accessories Available Colors/Finishes Stainless Steel (FGMV155CTF) Black Stainless (FGMV155CTD)
Frigidaire GALLERY™ 1.5 Cu. Ft. 900W Over-the-Range Convection Microwave
Save
Model No: FGMV155CTF
Features:
  • 170/300 CFM 2-Speed Exhaust Fan
  • Convection Option & Sensor Cooking
  • Express-Select™ Controls
  • SpaceWise™ Convection Rack
  • Effortless Clean™ Interior
1helpful
Frigidaire FMV158FMB power issue
Sounds like the door latch switch is broken and shorting out.
1helpful
I have a frigidaire Electrolux gallery series glmv168cqi microwave. The timer counts down, but the oven doesn't turn on. Sometimes when you open the door the fan turns on.
That would be a failing bottom door switch, or its mount.
My help file on door switches is here:
http://031d26d.namesecurehost.com/mwd/doorsw.txt
There's a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Once the control panel has been removed, you can access the door switches for testing and possible replacement.
There should be a technical manual hidden behind the controller or grille, too.
If you need further part ordering help, contact Electrolux:
USA
800•944•9044
North America
P.O. Box 212378
Augusta, GA 30917
Canada
866•213•9397 (English)
866•294•9911 (French)
North America
6150 McLaughlin Road
Mississauga, Ontario, Canada
L5R 4C2
I have a electrolux 1000w above range micro that stopped heating...maybe a fuse? Where is fuse?
if a fuse has blown then its very likley there is a fault inside this microwave,,,as for poking about inside it,,,dont!!!! even if you unplug it from the wall socket there will still be 1000's of volts kicking about in it and they can kill you if you tuch the wrong part,,,,is this risk worth taking???? its up to you!
6helpful
My Microwave oven makes a loud buzzing noise and appears as if its about to catch fire with flashing coming from the metal plate located on the right side of the oven. It's model number 7G65005787....
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually on the right side of the cavity and is about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If your waveguide cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
Your owner's manual may show you how to remove the cover.
You can download owner's manuals and installation instructions for Electrolux and Frigidaire here.
Otherwise, you can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
1helpful
2helpful
The model is FMV158FMB. What does the code SE
SE error means you have a shorted membrane keypad (called a membrane switch in this case).
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help here.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Microwave will no longer heat. Model #MA-1000W
So we can help you, please post a NEW question, and please include your model number MA-1000Was well as the answers to these questions:
When you try to microwave are the inside light, internal cooling fan and turntable all working?
Is there any unusual noise or is it louder or quieter than normal?
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
Will not heat at all
Could be the "board". Well known for failure. Get the part number from the board & search eBay for NEW board.Instructions probably on youtube
Top Electrolux Microwave Ovens Experts
Paul Bade
Jerry Naidoo
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
