Has it been stuck? Check the screws that holds the washer door. If the metal parts have corroded, the door probably is stuck. You might have to lubricate the metal parts to loosen it up.
It might also be caused by a broken door switch. You might have accidentally slammed it shut and now it won't open up. Pry it gently but you might need to replace the switch.
source: http://www.washingmachineadvisor.com
