SOURCE: i have a 1961 international 340 u tractor. i want
I should have taken an oil sample and let it determine by a oil analyze laboratory. Every hydraulic company can fix that for you.
It doesn't cost much. If you mix the wrong type of oils, you will be sorry to spend not that little money.
I don't know the quantity.
kind regards
Marcel van ****
SOURCE: is hydraulic fluid really used for both the
caseih hytran fluid is used for hydraulics and transmission fill through plate on top of deck next to shifter check plug is located on left side of transmission housing next to clutch linkage rod probably square headed pipe plug
