SOURCE: Need to reconnect (Power LED, Power SW, H.H.D LED)
Here is the diagram for your connection. It may vary but most probably there are names are written on the mother board for the connections
Thanks.
SOURCE: TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are
mainly,
Harddisk activity connector
This normally comes red in colour and is labeled
as HDD-LED
Power switch connector
This comes green in colour and is labeled as
POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled
as RST-SW
Power LED connector
This is usually green in colour and is labled as
PWR-LED
Speakers connector
This speaker will give different beep sounds
during boot to tell the user if there is any errors. It
occupies 4 pins, however only 2 is important for the
function. Be sure to connect the red coloured cable
to the positive polarity and the black to the
negative.
Front panel connectors pins on the
motherboard
Front panel connectors from the
casing
Good luck and thanks for using FixYa!!
SOURCE: Where do I plug in
When looking at the motherboard with the back of the computer to your left, there should be a row of pins on the lower right corner of the motheboard (or close to the corner). These pins are normally marked as something like PLED (for the power LED), PWR SW for power switch, RST for reset, IDE LED for the hard drive light, etc.
The power switch is normally along the bottom row and the power LED is on the top. But--to find where the power switch goes, take a small screwdriver and short two of the pins to see if the computer turns on. If it does, you've found the power switch. When the computer is running, put the power LED plug across two pins to see if the power light lights. If it doesn't, try two more until you find it.
var fctb_tool=null;
function FCTB_Init_88a0199091e74aa0ab8dd27b901b03c6(t)
fctb_tool=t;
start(fctb_tool);
SOURCE: MCP73VT-PM wiring diagram
When you are asking for a wiring diagram--just what is it you are needing? Do you need to know where to hook up wires? What is it you are trying to connect?
This appears to be an ECS board and you find what you need:
http://www.ecs.com.tw/ECSWebSite/Index.aspx?MenuID=0&LanID=9
SOURCE: MCP73VT-PM
MCP73VT-PM dont buy a pc with this board in it.I have had 7 in my shop these last 2 months.The board fails after abut 15 months.
