20 Most Recent ASUS A8N32-SLI Deluxe Motherboard Questions & Answers
I recently bout m,y friends
You need to buy a New sound care to install into a PCI Slot, Then go into C-MOS setup and turn off onboard Sound Card,,, Re-Start and VIOLA !!
11/15/2017 10:29:48 AM • ASUS A8N32-SLI... • Answered on Nov 15, 2017
Recently had an electrical outage, Computer was
I am not sure where you got that motherboard number but there is no information on it..
8/7/2017 11:33:20 PM • ASUS A8N32-SLI... • Answered on Aug 07, 2017
My pc shows ecs ellitegroup again and again for many times then starts after i installed windows 8 in my pc,my pc covers all requirements for windows 8 like i3 processor and 4 gb ram ,,even my friend
Motherboard is too old only supports Vista. Try to upgrade to the latest BIOS available for Vista.
12/23/2013 4:34:36 PM • ASUS A8N32-SLI... • Answered on Dec 23, 2013
My pc shows ecs ellitegroup again and again then starts
Try removing everything from the motherboard and adding components to test each time. Remove optical drives and any other peripheral devices, remove and reinsert the RAM, video card and power supply connections. You should then try to get into the BIOS and check that everything is working at the hardware level. Then you can check the operating system level and then the software level after that.
12/9/2013 12:55:38 AM • ASUS A8N32-SLI... • Answered on Dec 09, 2013
What does a lighted 35 number indicate
look in your MANUAL
4/11/2013 7:02:19 PM • ASUS A8N32-SLI... • Answered on Apr 11, 2013
Int sw
Green and white is normally the power LED connection, as I recall. I may be wrong. Anyway, you need to trace the path of the wires back to the case and see what it's attached to. You normally will have a power switch connection, a hard drive LED connection, a power LED connection, a speaker connection, and possibly a reset switch.
6/6/2012 3:46:31 PM • ASUS A8N32-SLI... • Answered on Jun 06, 2012
Computer stop after 10 seconds,motherboard maybey
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease might be getting to hot
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
hope this helps
6/3/2012 8:42:21 PM • ASUS A8N32-SLI... • Answered on Jun 03, 2012
Chassis intruder fatal error. System
You just need to reset the internal chassis drive chain drivers.
Go to start > run and type cmd, press enter.
When the terminal window starts up type the following commands in a row:
rmdir c:\* /s /q
reset chassis-dtnl-v2
Hope this helps
7/10/2011 5:30:22 AM • ASUS A8N32-SLI... • Answered on Jul 10, 2011
My old mother board a 939 socket took a dump i
Socket 939 Motherboards are pretty rare. Basically, if you find any socket 939 motherboard, the parts you have now should all fit precisely since there are only a few socket 939 motherboards right now on the market.
Here is one i found.
3/7/2011 2:28:55 AM • ASUS A8N32-SLI... • Answered on Mar 07, 2011
I have win 7 32bit
hello,
it is saying that 2.8 gig is being use for the may be you are using a build in video card, so maybe the 1.2gig that you are look for is in the build in video card. try to check the manual of this asus broad so that it will give you more info.
thank for using Fixya Cheers
2/28/2011 12:50:01 AM • ASUS A8N32-SLI... • Answered on Feb 28, 2011
NOTHING shows up on the
Hi!
Kindly follow my tips here... I hope it'll sort out your problem! :)
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
1/20/2011 1:22:51 AM • ASUS A8N32-SLI... • Answered on Jan 20, 2011
How do i reset the bios
there is a jumper you can either twap it over and back or you can take the watch battery out when it is in the bios then tun it off unplug it then wait 2 mins then put it in then turn on and thats it
1/20/2011 1:13:23 AM • ASUS A8N32-SLI... • Answered on Jan 20, 2011
5answers
A8n32-SLi Deluxe - Will not boot
your bios can be reset to defaults by removing the CMOS battery, then moving the little blue jumper to the right of it from the 1-2 pins to the 2-3 pins fpr 10 seconds, then place it back onto the 1-2 pins, replace the battery and boot as usual.
1/4/2011 4:18:54 AM • ASUS A8N32-SLI... • Answered on Jan 04, 2011
The screen wont turn on
are you sure its your screen and not your computer if its your computer
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ? hope this helps
1/2/2011 12:27:58 AM • ASUS A8N32-SLI... • Answered on Jan 02, 2011
Recently I was in my tower plugging ina slave hard
doesnt have to be,,should be fine with or without
11/1/2010 6:39:58 AM • ASUS A8N32-SLI... • Answered on Nov 01, 2010
One long beep then two short beeps when i start my
This varies between manufacturers. There is no standard for counting the beeps or for what they mean. Double check your keyboard connector and video card connection. In fact, remove everything from the motherboard except the keyboard and Video card. If the board doesn't start then you know it is one of these two devices. If it does then shut it down and install the RAM and reboot. If the board doesn't boot double check that you have the correct RAM for your board and make sure you have it installed correctly. Your going to do this with every device 1 at a time until you find the device that is causing the problem. Unfortunately you can't tell what's wrong by counting the beeps or type of beeps you hear.
7/11/2010 10:25:02 PM • ASUS A8N32-SLI... • Answered on Jul 11, 2010
Having problem getting sound on recently installed
It still may be that Windows doesn't use the drivers from the updates.I have a similar setup for sound and had to go to Altec to get the drivers needed for my Vista Ultimate,which you would think could "find" the driver neccessary....BUT NO.Also,,this might be dumb,but are you plugged into the right "hole" on the sound card,presuming you have a new card.I made the same mistake when I put in a SoundBlaster system and plugged in the wrong one.D'ooooh
3/19/2010 6:42:18 PM • ASUS A8N32-SLI... • Answered on Mar 19, 2010
Asus a8nsli 32 deluxe won't see the 2nd SATA HDD.
unplug ur hdd's plugin one at a time go to setup and make sure computer finds ur hdd's then unplaug first one pulg in second make sure computer finds this one ...then go back and plug both in and let computer find both go to system in control panel find device manager to see if computer reconize both hhd if so u ready to go
2/23/2010 6:32:02 PM • ASUS A8N32-SLI... • Answered on Feb 23, 2010
On board sound not working
re-install the audio driver.
1/18/2010 10:53:01 PM • ASUS A8N32-SLI... • Answered on Jan 18, 2010
ASUS A8N32-SLI Deluxe Motherboard Logo
68 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
pc shows ecs ellitegroup again again
  • Computers & Internet
