Nortel Norstar 16-Line PBX Speakerphone Logo
Posted on Aug 04, 2010
Program 7310 nortel phone - Nortel Norstar 16-Line PBX Speakerphone
Anonymous
Level 1:
New Friend:
  • Contributor 105 Answers
  • Posted on Aug 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
105
Questions
0
Helped
41530
Points
Here are the most common programming features:
1. Feature * 0 - Button Inquiry
2. Feature * 1 - External Autodial
3. Feature * 2 - Internal Autodial
4. Feature * 3 - Assign Feature to a Button
Hope this helps!
Nortel 7310. Mailbox not accepting new Voicemail messages. I do I clear?
You need to delete old messages - the limit is 50. follow the display when using the VoiceMail retrieval method you regularly do.
1helpful
2answers
Cant change time and date on nortel t7208 phone tried the f xx23646 and so on, nothing
Programming on the nortel system is done on M 7310, M 7324, or T 7316 sets only.hopfully the receptionist station has one of the larger sets.
2answers
I need different ringtones on my Nortel 7310
you should already, intrnal is double ring and external is long single ring. you can set sounds from the softkeys below display.
3helpful
How to change the time and date on nortel phone
Programming2.gif is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say A. Configuration. The 4 top line/feature keys are now used for programming.
Press "NEXT"(bottom right arrow)
display should read B.General Administration.
Press the show key (top right arrow)
display should read 1.speed dial
Press the next key 2 times(bottom right arrow) .
display should say 3.time and date
display should show current programmed time
Press the Change key
Enter in time in 12 hour format
press ok
press either Am or PM when prompted
press ok
press the Rls key when finished
3helpful
How do i change the names that are on the display on a Nortel 7316e
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the name on.
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
7helpful
I have a Nortel T7208 can't change main greeting
to change the main greeting you need to get into admin programing F983 your also going to need a 7310 or 7324 or a T7316. You have to use the buttons under the LCD screen to navigate after getting into admin press AA
Press GRTG
Press GRTG again
and usually 1 is set for day
and 2 is set for night
press 1 then ok
Press REC.
Hope this helps
Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Carl
M7310 phone buttons
Wow, you should get 2 lines and at least one intercom by default. Lines are assigned in most Nortel systems in Terminals & Sets. Your COPY command is your friend. Just pick a phone you wnat to emulate and copy it to your new set.
Carl
2answers
Norstar 7310 forwards to Voicemail
Sounds like the phone is set for Call Forward Busy/ No Answer instead of Call Forward No Answer. If you cahnge it call forwarding it should work correctly. ....Mike
Top Nortel Lands Phones Experts
vince
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
