http://www.csgnetwork.com/oilfuelcalc.html
In the Mix
All STIHL gasoline-powered equipment uses a 50:1 gasoline/oil mixture. The chart below can help you figure out the correct measurements to use. For high-performance fuel that requires no mixing, choose STIHL MotoMix® premixed fuel.
The choke is on the carb. Check if the carb set screw is set right, turn it all the way in and then back out 1 1/4 turns. then fine tune by 1/4 turn increments.
husqvarna 142 e will use 91 octane fuel is ok and use qood quality 2 stroke oil
at the ratio of 50:1 premix that is 20 mils of 2 stroke oil for 1 litre of petrol that you mix
so if you want to make a 4 ltre mix add 80 mils of 2stroke oil to clean container and add 4 litres of petrol only and give good shake then fill saw
Like most 2 stroke weedwackers they run on a 25:1 fuel ratio.
It is advised that you mix the petrol & oil in a separate container (remember to shake it for a few seconds) first to ensure it mixes properly.
Example:
1 Liter of petrol needs 25ml of oil. (Use 2 stroke oil)
Hope this helps.
well it is 2 stroke so if its rev'in slow thats not dunna help . my sister had one and its the kind of thing that u don't let it idle just keep it going. thats what i found best
