On my C-H vertical 60 gal, Isee only one adjusting screw over the large spring for the cut-out pressure. I cannot find any other type of adjustement for cut-in pressure nor than for the differential pressure. So, If I adjust the cut-out pressure say at 115 psi, the cut-in presure is decreased proportionally. That cause to have pressure dropping in the tank at 80 psi for the compressor to start. I would be able to set the cut-in pressure at 95 psi to always have 90 psi at the end of the hose considering the pressure drop of the FRL, fittings and the hose.Any clue?
I think I follow you... the adjuster over the large screw is used to set your tank pressure but also sets the cut-in/cut-off pressure. You have another regulator to control the pressure to and thru your hose but that doesn't insure that you won't exhaust the tanks supply and use more air than your pump can produce. It doesn't matter what pressure you set it at if your pump can't produce enough cubic feet per minute of air to keep up with your output. If your air use/output is within the pumps output, your idea will work just fine and you can set the hose regulator just below the cut-in pressure but Remember, even a little airbrush uses a lot of compressed air but sanders, grinders, sprayers and impacts use a Ton so don't try this without having somebody monitor the compressor periodically while you try it. It all depends on your air demand.
SOURCE: high/low pressure spring settings
Generally, the pressure switch is not adjusted more than once or twice in the life of the compressor since the discharge pressure can be adjusted with pressure regulator. However the life of the compressor can be increased if lower pressure settings are maintained. Your pressure switch was set at the factory to a setting of about 120 - 150. If your cutout pressure is higher than 150 surely lower.
STEP 1: Turn Main Calibration Screw ( center screw with large spring) clockwise to increase pressure and turn counter-clockwise to decrease pressure.
STEP 2: Turn Differential Pressure Screw (small spring) clockwise to decrease cut-in pressure and
turn counter-clockwise to increase cut-in pressure.
Differential Pressure is defined as the difference between cut-out and cut-in pressure. There should be about 7 to 12 psi difference between cut-out and cut-in.
In our shop we rarely adjust more than a couple of turns because these switches are sensitive.
Good Luck and please post again if you have other concerns about your compressor.
SOURCE: Drops compressiom from 120-60 psi after 3 new pressure switches
When the pressure switch fails the comperssor will overpressure to the point of safety release at about 150 - 160 psi. It sounds as if your compressor is not producing enough pressure to cycle off at 120 and just keeps running. This happens when air is leaking from fittings or worn cylinder / reed valves. Don't worry, with some simple tests we will find the actual problem. I am assuming that your compressor is oilfree type. If there are leaks the compressor may not reach set pressure. I use soapy water on all connections and on the head/headvalve (remove plastic covers to get to all parts that may leak) while compressor is running. Make repairs as necessary. If still low pressure, while compressor is running and has reached max obtainable pressure (in your case 60 lbs), carefully place finger over intake port hole (remove filter). If the compressor is pumping normally but leaking there will be ample suction at intake and cause the compressor to speed-up when intake is obstructed with finger. If you feel plenty of suction and no visible (soapy water) leaks, then the problem is probably the cylinder /ring is not correctly seating /scratched and air is leaking past cylinder. Make sure that the cylinder /piston ring is properly aligned and that the lip on the vinyl ring is up toward the head. On oilfree compressors you can examine the cylinder by pushing the piston all the way up, then look for scratches neer top of cylinder. If scratched, pressure is leaking past cylinder, install cylinder kit. If you do not feel suction but rather air blowing out of the intake, (do this test when tank has reached 60 psi) then the problem is the headvalve plate/reed valves are leaking. The reeds must seal perfectly on their seats and not be bent or have obstruction. Replace as necessary. If reeds or headgasket is leaking the discharge air will be very hot. Only one other thing to check and that is the intank check valve. Easy to check. Run compressor till you have about 50+ lbs in the tank then unplug compressor. Carefully loosen the inlet hose at checkvalve and listen for air leaking out of tank. (check valve is the brass valve at tank) If leaking replace checkvalve. Use caution when removing head to try and save the gaskets. If you have oil type pump, and no air leaks (soapy water test) suspect reed valves/valve plate. Good luck on your repair and email if you have other question.
SOURCE: Air compressor motor stalls under pressure
this sounds like a bad pressure switch.if the unit is not shutting off at the same pressure each time this would be the cause.2 if the pressure is not unloading the air pressure on the compressor side of the unit it will cause the unit to struggle when it starts a cycle because the piston is under a load .how this works is say the unit starts from 0 psi when it get to the desired pressure you have it set on the unit kicks off . the other adjustment most units have on them is what pressure to cycle back on.so when the unit reaches say 100 pounds ,it kicks off and bleeds the air off the compressor side so when it starts back up it wont start up with pressure on the piston.
SOURCE: wanting to adjust my cut off pressure down...its
If I read your problem you would like to decrease your pressure setting on a campbell hausfield compressor, this usually can be done by turning the 3/8" nut (typical) counter clockwise which decreases the spring tension on the pressure plate allowing less pressure to break the points. Hope This Helps Don
SOURCE: I have a model FP209501 Air Compressor 2 Gallon,
The spray gun consumes more air volume than the compressor can deliver. You can pause painting periodically to allow the compressor to 'catch-up' or buy a larger delivered-volume compressor. The compressor that you have was intended to supply air for pneumatic nailers and staplers in an intermittent fashion. Hope this helps!
