I need a wiring diagram showing the power hookups for an e machines t2200 the previous owner pulled them off without labeling them and we cant figure out where they go
I have an emachine that is a 1900+ series and need to know how to wire the power supply. I don't see a place on the motherboard for the 12v 4 pin connector.
If you are replacing the power supply and it has 4 pin 12v conector and your motherboard doesn't, just disregard the 4 pin plug. The 20 pin conector will supply sufficient power for the processor. Many of the older motherboards did not have a separate 12v supply for the processor.
I need wiring diagram for my emachine t2042! I can't figure out where the red/white, green/white and black/white wires go!
I already know where the power supply wires go, everybody does- they're all the same!
I have a E Monster 500 that was given to me,but everything was taken loose inside.I now have 2 wires that I can't figure out where they go.1 is 4 wire,red,white,& 2 black.The other is 3 wire,red,white,black.Can anyone tell me where these wires go?
ON off switch wires
t2042 wiring diagram needed.
i have an emachines t2862 and cant figure out what order the pwr switch pwr led and hdd led wires plug into can any one help how do i determine what motherboard is in this cpu
pc won't start up
i have an emachines t2862 and cant figure out what order the pwr switch pwr led and hdd led wires plug into the motherboard. On the motherboard, there are 4 sets of 2 pins and 1 set with 1 pin. Can any one help how do i determine what order the 3 plug into the board, starting with the single pin?
