20 Most Recent E-Machines EMA IMPERIAL GV (845GV) TG3 eMachines (145119) Motherboard Questions & Answers
Emachine user manual
is this the one you're looking for. Download emachine w2646 motherboard manual 0 views
6/2/2015 9:36:39 PM • E-Machines EMA... • Answered on Jun 02, 2015
Emachines Imperial GV 20030812 Motherboard manual
THE MOST EASY WAY TO CLEAR CMOS JUST REMOVE CMOS- BATTERY FOR 10-20 SECONDS.IT LOOK LIKE A WATCH-BATTERY.BE CAREFULE WITH THE HOOKS.
12/4/2013 10:13:36 AM • E-Machines EMA... • Answered on Dec 04, 2013
3answers
No Power up on depressing On/Off button.
Sometimes if the CPU is overheatign it will power down to stop the cpu from buring out. A power suppluy just supplies power to the motherboard and that's it. If the CPU gets hot it shuts down and wont start till it cools down again.
11/25/2013 5:51:05 PM • E-Machines EMA... • Answered on Nov 25, 2013
Graphic Card download
go to emachjne web site download support from there ok
11/11/2013 8:22:58 AM • E-Machines EMA... • Answered on Nov 11, 2013
Why doesn't my hard drive power up unless I disconnect the data cable.
Hello here is the homepage:http://support.gateway.com/us/en/emac/default.aspxI think your harddrive has a defect and must be renewed.The mainboard could also be failing.Good luck
4/1/2013 1:37:16 PM • E-Machines EMA... • Answered on Apr 01, 2013
What type of graphic card are compatable with emachines T3624 Pc's
Hello here are the homepage:http://support.gateway.com/us/en/emac/product/default.aspx?modelId=1581This mainboard has the PCI-e graphic card socket, and a AGP graphic card will not fit and run on it.A PCI-E graphic card, can be bought in a computer store or online.Does the pc boot at all ???If not try to renew the power supply.Good luck
3/31/2013 2:56:07 PM • E-Machines EMA... • Answered on Mar 31, 2013
E-Machine 4260 user manual
emachines.com
2/23/2013 11:38:39 PM • E-Machines EMA... • Answered on Feb 23, 2013
0answers
Emachines network card drops off internet
check all leads and connections to modem / routeryou will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question / exclamation mark ? ! or a red X right click install drivers the driver might be on the disc supplied by your ISP internet service provider or the motherboard disc
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledimake sure its enabledPci device arrows key scroll to nstalled. hope this helps
10/18/2012 2:39:54 AM • E-Machines EMA... • Answered on Oct 18, 2012
Drivers for imperial glve 20021218
if you computer came with a motherboard disk the drivers could be on it
or you might have to download them
rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
they will automatically search for and find the correct driver also http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for (be precise)dont use numbers and / - you might have to try a few times to get it right also the download software finder under that there will be a list place a tick in the box of any one you want/need
hope it helps you
4/12/2012 12:24:39 PM • E-Machines EMA... • Answered on Apr 12, 2012
3answers
Replaced hdd on emachine w3615,light on mobo but it wont come on.
Hi ipackrat21, that little green led you see is telling you the motherboard has standby power. (Its supposed to be green & on).
Make sure the hdd jumper is set to, master without a slave). In a one hdd system.
When you replaced the hdd you also need to enter the bios menu.
In the bios you'll need to make some changes. First you should see the new hdd listed in the bios. (Normally it list the hdd by model). If your hdd is shown than go to the title "BOOT". You need to set the boot order. A normal boot order would list like so;
First boot device, Floppy disk drive".
Second boot device, "CR-ROM" drive.
Third boot device, "Your new hdd".
If your bios does not see your hdd you'll need to re-check the data cable from the board to the drive. (Make sure it is fully connected).
If the drive is an IDE/PATA make sure it has power. A 4-pin molex.
010e000.jpg Good luck ipackrat21!
Still have trouble, post it here.
Mike
3/16/2012 1:49:09 AM • E-Machines EMA... • Answered on Mar 16, 2012
0answers
I need display driver plz
Hi, you can download the driver here:
http://support.gateway.com/us/en/emac/product/default.aspx?tab=2&modelId=1434
If not the right driver search by model and number.
The driver maybe needs to be unziped before installation.
Hope this will help you.
3/30/2011 9:12:29 AM • E-Machines EMA... • Answered on Mar 30, 2011
I put W 7 32 bit on imperial GV 20030812 but the
Hi Good day!!! Try to upgrade your direct X click here http://www.microsoft.com/games/en-US/aboutGFW/pages/directx.aspx if still bad maybe your graphic hardware is not compatible for windows 7, by the way what operating system you use before you install windows 7?
Please reply if you have further problems i will assist you more
Thank you for using FixYa
Please accept if my solution helps you
11/10/2010 3:21:54 AM • E-Machines EMA... • Answered on Nov 10, 2010
I put W 7 32 bit, but the video resolution is no
Hi Good day!!! Try to upgrade your direct X click here http://www.microsoft.com/games/en-US/aboutGFW/pages/directx.aspx if still bad maybe your graphic hardware is not compatible for windows 7, by the way what operating system do you use before you install windows 7?
11/10/2010 3:17:08 AM • E-Machines EMA... • Answered on Nov 10, 2010
Computers & Internet Logo
73 questions posted
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • E-Machines Computers & Internet
Most Popular Question
  • Computers & Internet
