blank screen &can shut down problemblank screen &can shut down problem
AnonymousApr 17, 2008
my phone keeps on shutting down, a blank screen appears then after secs the phone shuts down. i was wondering if a virus could have caused the problem. pls helpmy phone keeps on shutting down, a blank screen appears then after secs the phone shuts down. i was wondering if a virus could have caused the problem. pls help
You can't post conmments that contain an email address.
? try removing the battery and then connect the adapter to turn on the computer
? if it is turning on then disconnect the cable and hold down the power button for 2 mins and try turning on the compute
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on? If stays on, then inverter turns into protection mode because of old backlight lamps. If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Don't know why the screen is blank. Toggle the F9 key to make sure you didn't accidentally toogle off the screen.
As far as turning off the power and shutting down the computer, the old stand-by is to take out the battery and then pull the plug. The computer will power down. Replace the battery, replace the plug and then push the start button. You may have to start it up in SAFE mode since the shut down process was not the "normal' process the computer expects to follow.
Without more information I cannot be sure, but I would say that it could possibly be set to use an external monitor. There is a FN key command to switch between your LCD Screen and an external screen. Try that. If you have an external monitor that you can plug into the VGA connection, that should tell you for sure. Good luck.
Maybe the setting of your video display was change to higher setting, and your screen cannot handle the said setting.
When a "safe mode" message appears during opeing, select that options, then at the desktop right click your mouse, chose properties, then setting, then change the screen resolution to lower range.
