20 Most Recent Dell E152FP 15" Flat Panel LCD Monitor Questions & Answers
3answers
I am getting a self test feature check box floating around on my
check your vga cable!
3/18/2023 6:49:24 PM • Dell E152FP 15"... • Answered on Mar 18, 2023
My home dell computer monitor
The dialog box you are seeing means that the monitor is not receiving a signal from the computer. check your cable going from the monitor to the computer. if the cable seems ok, hold the power button on your towerr until it turns off, then wait 5 seconds and push the computer power button again. Cheers
12/26/2017 7:15:42 PM • Dell E152FP 15"... • Answered on Dec 26, 2017
Where is the menu button?
24633773-o3nmobphinvsto2ybs4ztnnh-5-0.jpg I hope this helps you with your issue.
10/8/2016 3:56:44 PM • Dell E152FP 15"... • Answered on Oct 08, 2016
No display
On the front panal you should have some config buttons for the monitor setup. One of the buttons also switches video input mode but you have to hold it for a couple of seconds and it switches from dvi mode to analog. That may fix it.
11/23/2014 11:33:23 PM • Dell E152FP 15"... • Answered on Nov 23, 2014
0answers
Problem with Dell E152FP Monitor
If you open the monitor up, on the inverter board is a 1000uF 16v capacitor that goes bad. If you replace that it should fix the problem. Look at the top of all the capacitors and you should see one that's popped up on the top, that would be the bad one. Some soldering is required. Make sure you put the negative white stripe on the white side of the silk screen on the board! Its a simple fix just sounds difficult.
5/20/2013 10:51:20 PM • Dell E152FP 15"... • Answered on May 20, 2013
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
1/30/2013 6:35:40 PM • Dell E152FP 15"... • Answered on Jan 30, 2013
I have a E152FP monitor will this work with a graphics card that has a DMS-59 connection
The monitor will work with that video card but the resolution needs to be set to 1024 X 768 or less. Your video card is trying to display the picture at a resolution that the monitor can not handle correctly so you get the video mode error. You will need to use the windows video settings screen to change the settings for that display than you will be good to go.
9/27/2012 3:23:05 PM • Dell E152FP 15"... • Answered on Sep 27, 2012
Red screen on E152fpc monitor
Hello, A red or pink tint on LCD monitor indicates that the CFL backlight bulbs are failing. These are just like the florescent bulbs you use at home and the office but much smaller. When they are about the fail they will have a red tint to the light instead of white. They can be replaced but on a 15" LCD its not worth the price and trouble to do it. The bulbs will run about $35 and then about 1 hour to install if you know what you are doing. It would be better for you to get a replacement monitor.
5/8/2012 7:02:46 PM • Dell E152FP 15"... • Answered on May 08, 2012
2answers
My monitor will not maintain a picture. The
This is the back light. If you are lucky the solder or a cable has let loose on the bottom of the screen inside the case and you can redo them. This of course voids any warranty. If you are unlucky you are looking at a screen replacement.
11/23/2011 10:53:59 AM • Dell E152FP 15"... • Answered on Nov 23, 2011
Dell E152FP (Black) 15 in. Flat Panel LCD goes
Check for bad caps with domed tops.
http://s807.photobucket.com/albums/yy352/budm/DELL/Dell%20E152FPC/
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
6/14/2011 3:52:54 AM • Dell E152FP 15"... • Answered on Jun 14, 2011
How do I upload a
You will need to sighn up for FixYa, seeing that you've listed this question I'm guessing you've already done that. Then you can create tips, once you have created a tip that is of good quality and length you can apply to become a Premium tip expert.
5/26/2011 9:54:09 PM • Dell E152FP 15"... • Answered on May 26, 2011
A blue lock appears in
http://support.dell.com/support/edocs/monitors/1901FP/en/controls.htm
Go here and look at how to disable the OSD lock; try holding the menu key for 15 seconds on the monitor.
3/9/2011 8:04:22 PM • Dell E152FP 15"... • Answered on Mar 09, 2011
Blue lock pops up. can not use menu buttons.
The lock that pops up is called OSD Lock, with this there are no adjustment can be made by a user and only menu button will work. For you to disable it, just press the menu button for about 15 - 20 secs.
To know more about the controls of your monitor please click on the link.
I hope this will be able to help you resolve the problem.
Thank you for choosing Fixya
3/6/2011 8:53:41 PM • Dell E152FP 15"... • Answered on Mar 06, 2011
2answers
I have a Dell 1905FP
Try deconnect and reconnect the screen to the computer. You can also try to use a different cable or port on your computer to connect it. Also, in the "video preference" of your computer, be sure you activate this monitor.
3/1/2011 12:28:51 AM • Dell E152FP 15"... • Answered on Mar 01, 2011
My monitor is stuck on
I'm currently having the same issue, but after some research I have found that it may be that your video cable is disconnected or damage. I hope this helps.
10/24/2010 11:24:11 PM • Dell E152FP 15"... • Answered on Oct 24, 2010
Dell E152FP 15" Flat Panel LCD Monitor Logo
104 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
  • Dell Computers & Internet
Most Popular Question
i am getting a self test feature check b
  • Computers & Internet
