VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100 MATX Form Factor1xAGP (4X) / 2xPCI / 1xCNR / 2xDDR / 2xDI... (2277200350) Motherboard Logo
Posted on Jun 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the upgrade cpu for this motherboard - VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100 MATX Form Factor1xAGP (4X) / 2xPCI / 1xCNR / 2xDDR / 2xDI... (2277200350) Motherboard
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 14, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
233
Points
I brought G41T-M7 motherboard then i have dual core processor 1.60ghz, ddr3 4gb ram, when i start my system my processor fan only one time rotate then stop what can i do please help me plssssssssssssssss.....
Anonymous
Level 3:
President:
  • Master 2,351 Answers
  • Posted on Jun 14, 2010
Anonymous
Master
Level 3:
President:
Answers
2351
Questions
Helped
1591188
Points
6609
The following processor are currently supported by this mainboard.
Athlon XP: 1500+ up to 2000+; FSB: 266 MHz
Athlon: 650 MHz up to1.4 GHz, FSB: 200 MHz or 266 MHz. Socket A CPU. See page 10 in you're manual (If you still have one). After going to Elitegroup and checking for the latest bios version;
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=67&CategoryID=1&MenuID=50&LanID=9
BIOS for K7VMM(PCB:1.2A). Release date, 2003/03/28
The MB will support, AMD Athlon XP 2400+ and 2600+ CPU If you're bios is flashed to the above. You can buy and use this CPU; http://www.sjkksales.com/servlet/the-461/AMD-ATHLON-MP-2600/Detail
Never flashed a bios? Instruction are listed on ECS web site.
Mike
1helpful
Cpu upgrade
A) http://www.fixya.com/support/t18040647-cpu_upgrade
B) http://www.fixya.com/support/t18040647-cpu_upgrade
(Last time I looked, this was the world's largest product support website, and there ARE technicians from AROUND the world; on here!!!!!!!! Do we count as an 'IT techie'? ........Lol!)
In all three of your posts, not once has the laptop manufacturer name, and model number been stated.
Processor (CPU) support depends on;
A) What processor socket is on the motherboard?
B) What motherboard chipset does the motherboard use?
C) What is the processor that is installed now?
With these parameters known, THEN you can think about CPU (Processor) upgrade.
1) CPU (Processor) has to FIT, the processor socket being used.
THIS, is also IF the motherboard HAS a processor socket; and is NOT soldered directly to the motherboard.
2) The motherboard chipset supports the Processor (CPU)
It has to be known if the motherboard chipset will support, the CPU (Processor) that you want to upgrade to.
For older computers the motherboard chipset consists of;
A) Northbridge chip
2) Southbridge chip
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
With this technology the Northbridge chip, of the motherboard chipset; is what determines Processor (CPU) support.
Newer technology, such as used per se by the Intel Core i processors, does NOT use a Northbridge chip.
3) Looking at the existing Processor now, you can determine;
A) Voltage Range: What voltage range does the exisiting Processor use now?
Does the upgrade Processor also fall within this Voltage Range?
B) Core technology, and architecture:
Example:
Existing Processor uses the Conroe Core technology, and the 90nm architecture. (NanoMeter)
Does the upgrade Processor also use the same Core technology, and architecture?
If not is there a BIOS upgrade available?
(The motherboard chipset also comes into play again, here)
Enough of this generic prattle.........
Post the laptop manufacturer name, and model number.
Then I, or someone else can give you the facts; and not generic information.
Post back in a Comment.
Regards,
joecoolvette
http://www.hardwaresecrets.com/article/535
http://en.wikipedia.org/wiki/Northbridge_%28computing%29
I have a Intel D845GBV socket 478 and burned out my 2.7 g cpu. i would like to know if i can upgrade this board
You can only upgrade as high as your components will allow. If you get a brand new motherboard, you'll also need to get the appropriate RAM, and CPU style. When you're looking into buying a new motherboard, especially to replace a single core motherboard, you usually have to upgrade RAM, CPU and possibly video card, if you're using an older AGP style video socket - so make sure that if you DO upgrade your board, you either keep it within the limits of your components, or upgrade the appropriate pieces along with the motherboard.
1helpful
I have an Intel D845HV motherboard running with a
In short, yes you can upgrade to a P4 cpu but from the compatibility chart at Intel support, it looks like the upper limit for this older board is the P4 2.6GHz.
Note: Even at that, running the P4 2.6 would require a BIOS upgrade to P12 or greater.
Luckily, the following link has the information you seek: (for BIOS info, click the "BIOS Version" link in the upper right corner of the compatibility table provided)
Intel D845HV CPU Compatibility
I hope this info is helpful!
1helpful
I want to upgrade the cpu on a se440bx-2 slot 1 PIII motherboard
If you go to www.motherboards.org and type in your motherboard, it will find it and give you all the information that you need.
1helpful
Can the cpu be upgraded to BX80526C1000256! If yes what modifications need to be made? Motherboard is EliteGroup P6STP-FL
Hello!
If you want upgrade you CPU, you must first know, specification of motherboard.
If the motherboard can´t see a new CPU, more exactly bios, you can try only one upgrade bios.
I give you a link for a manual and upgrade bios.
When you upgrade bios, try new CPU, if bios again don´t see a CPU, you can´t do anything about that.
I have an intel celeron 1.79 GHZ on my dimension 2350,what is the better processor for upgrade? and is there something else that i should change inside for the new processor?
you said that you want to upgrade ur 1.79ghz celeron cpu.
to upgrade a cpu just check that the packaging of the new cpu matches with the motherboard.
and also check that the motherboard supports the new cpu that you are installing. check this in the manufactures site.
Upgrading CPU
This motherboard? asus p4s800d-x?
Nope - No
Intel Celeron or Intel Pentium 4 Cpu's for this motherboard.
2answers
Asrock p4i65g motherboard
Your current motherboard is an mATX form factor. I recommend staying with that form factor for your new motherboard if staying with your current case. When upgrading to the new board you choose don't forget that you may need to upgrade the power supply unit also. You should upgrade to either a socket AM2+ board with dual core amd cpu or socket 775 board with Intel Duo Core2 cpu.
2answers
Upgrade
to upgrade your going to have to take the laptop apart and remove the heatsink on top of the cpu, then disconnect the cpu, and then install another cpu in place of it, apply therman greeze and put the cpu heatsink back on. and reassemble your laptop.
2helpful
2answers
CPU Upgrade for Compaq (283983-001) Motherboard
download and run everesthome
click on the + by motherboard
click on cpu then click on motherboard
the cpu will id the the processor
motherboard will id the FSB speed.
CPU-Z
click on the download latest version, left column
when you unzip and run this it will tell you if the processor is 478 or 479 pin both have 478 pins but location is different.
Top VIA Computers & Internet Experts
MegaByteMe
MegaByteMe
Aron
Steve Pack
Steve Pack
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
