20 Most Recent
Compaq (283983-001) Motherboard Questions & Answers
How to install 2.4ghz processor in d510 motherboard
hi,the compaq evo d510 SFF has compaq motherboard ( i cant find the modelname) but definitely for this model of compaq with 2.4 ghz 512/ 533 parts no: SL6RZthe other processor of the other one that i installed is pentium 4 2.8ghz 1M/533 parts no: SL7K9 and motherbord of D845EPI/D845GVRCan you please help me to figure this out and it is possible to switch this processor? Im just trying to use the compaq with faster processor..Thank you so much
10/20/2013 6:20:14 AM •
Compaq...
Answered
on Oct 20, 2013
P/N: 283983-001 motherboard
Here ya go fellas... (freakin geeks is really starting to **** and so is compaq/hp for not supplying pdf manuals for this old junk...
2/18/2013 3:09:24 PM •
Compaq...
Answered
on Feb 18, 2013
COMPAQ Evo D310st
Please go to Bios setup and then Load the bios set up default, and restart the system.
If this not work, Please replace the CMOS battery maybe that battery is busted. and the do again"
"Please go to Bios setup and then Load the bios set up default, and restart the system. "
hope this help!
If not solve the problem please notify me, do not rate.
10/29/2011 2:23:59 PM •
Compaq...
Answered
on Oct 29, 2011
511-cpu fan not detected
are you the one opening your desktop computer?
If you are, check your cpu-fan connector pin if its properly connected to the motherboard
If not
check if your cpu fan are working if it didn't rotate replace it with a new one
7/26/2011 2:17:03 AM •
Compaq...
Answered
on Jul 26, 2011
My compaq computer lost all power after I replaced
One thing to check is, you knwo the power cable that goes into the dvd player, this some times can go in upside down. if it has its blown your board , but there is a chance it hasnt make sure its the right way, and try again.
4/6/2011 5:43:48 AM •
Compaq...
Answered
on Apr 06, 2011
My motherboard does not accept any memory i fix in
the beeps windows/bios is searching for the operating system make sure your bios settings are correct you could try another hard drive and see if the problem is cured
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
2/21/2011 8:03:06 AM •
Compaq...
Answered
on Feb 21, 2011
Chassis fan not detect
there are two ways a chasis fan can be connected....
1)to the motherboard(it should detect)
2)directly to the SMPS(it wont detect)
if its connected to the SMPS, then remove and plug to the fan port for external fan on your motherboard.......i wud personally advice you to leave it as it is if the fan is working properly......moreover its not necessary for the chasis fan to be monitored....HOPE IT HELPED................DO VOTE IF IT HELPS.........
1/18/2011 3:49:37 PM •
Compaq...
Answered
on Jan 18, 2011
check fan if fan ok then check hard ware near fan jack sarfaysamandit fet or transister
if fix your problem click yes for vote
12/27/2010 8:55:22 PM •
Compaq...
Answered
on Dec 27, 2010
