E-20 error is for drain pump /filter blockage.
Drain the pump manually.Clean it internally.The filter and drain pump are getting blocked in your machine.It needs to be cleaned.In some cases drain pump needs to be replaced if its cracked.
This will help.
Thanks. keep updated for any more query.you can rate this solution
and show your appreciation.
SOURCE: Error message on washing machine E20
E20 is "A problem with water draining"
Solutions:
The drain hose may be squashed or kinked
the drain pump may be blocked
or possible your filter is totally blocked. Clean out the filter
everything will work again. Put a large bowl under the filter as you
unscrew it; a fair amount of water could be there.
Good luck.Please rate the solution if accepted, also do post comments in case of any doubts.
SOURCE: E20 error message
The E20 error code means - not draining It seems more as an issue of a clogged drain line or malfunction pump.
SOURCE: Water won't drain, error message: E20
error code E20 means that the coin trap/drain pump hose needs cleaned out.It can be done by the owner with a friend helping.
1. Unplug the unit.
2. Tilt the unit up to where the front feet are in the air and the back feet are still on the ground. Please make sure the unit is propped up safely.Or you can lay the unit on its back side.
3. Now that the unit is propped up look inside the hole on the bottom of the unit - on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
4. Clean the drum out with as much water as possible and have towels ready. The next step you will have the remaining water come out.
5. At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum.
5. Reach inside the coin trap and clean what is inside of it out.
6. Put the unit back together following the same steps backwards
Of course, if your washer is setting on top a drawer/pedestal then you will need to take out the screws that connect the two and then you can lay the washer down on its back onto the pedestal
SOURCE: What does the error message e20 mean on a front
hello,
what this sign means or indicate is an error code indicating that there is an over flow of water in the sensor / lens reader circle.
what you are to do to fix up this problem is to unscrew then washer then clean up all form of water or any form of liquid substance around the wire connected to the panel on the screen carefully do this assignment with care and avoid disconnection on other wire connection then couple it back has it was then problem of the e20 (error)is solve.
please note this,
PUT OFF ALL FORM OF POWER SUPPLY CONNECTED TO THE WASHER BEFORE DOING THIS ASSIGNMENT.
Thank you and thanks for using fixya.
SOURCE: error messages displayed on my zanussi iz12
e40 the door not been closed e20 the drain hose may be kinked
