Not sure what the OE is, but I;ve been having the same letters flashing on my washer this week. I checked the filter at the bottom and it was totally plugged up ! I would check your filter.
OE flashed on my machine. I read this solution, checked my filter - it was full of junk. I cleaned out the filter - error message gone and machine works again.
SOURCE: not spinning. code oe shows
Kenny welcome to FixYa. This code means that the pump is probably clogged. You need to get inside the washer and inspect the water pump. Articles and items can get into the pump and block it off. If you do not have a back panel to get inside through, there should be screws on the top sides of the display. You can get in through this way. If you have any questions, let me know. Best regards, Ricky.
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
