Tip & How-To about Washing Machines
LG Washing Machine OE Error Code
Your LG Washing Machine has stopped and is giving you an OE error code. What does this mean?
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. If you are even a little bit handy, there are a couple of things that you can do to try and avoid a service call.
If you have a LED model you will see this
If you have a LCD model you will see this
The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter. Some common obstructions are detergent build up, hair, coins, etc…
First make sure that you unplug your washing machine.
To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.
Here are some other things to check if cleaning the filter does not solve the error code.
Check the drain hose to make sure that your do not have it installed too high up. The pump will not push water up much higher then 1 meter.
Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.
http://www.fixya.com/support/r4342015-lg_washing_machine_ie_error_code
http://www.fixya.com/support/r4341906-ue_error_code_lg_washing_machines
http://www.fixya.com/support/r4341798-lg_washing_machine_oe_error_code
http://www.fixya.com/support/r4341643-lg_washing_machine_error_or_fault_codes
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
Washing Machines Logo
wont spin keeps coming up with oe on screen what does this mean
OE error code indicates that the washer is unable to drain the water it used during the wash cycle. OE can be triggered by a kinked drain hose or a clogged drain pump filter.
LG washing machine error code OE. Error code OE on The LG washing machines simply means the pump is blocked. Presumably the water isn't being emptied properly you might have something blocking the pump.
https://www.youtube.com/watch?v=JBCodfFo6Bc&vl=en
https://www.youtube.com/watch?v=KixjQQdGNF4
https://www.youtube.com/watch?v=A4ENzr2ZR1c
Oct 07, 2018 | Washing Machines
My LG washing machine is showing OE fault what do it mean ?
OE means uneven load.
If you can open door, put a dry towel in with the washing and try spinning again ...
Nov 20, 2017 | LG Washing Machines
OE error please
There may be a few different reasons why the OE error code can display on your washing machine. Is it the LG washer getting the OE error code? The OE error code on the LG washing machine display is an indication of a NO DRAIN issue. The 3 issues that may cause this fault code is a bent drain hose, the drain pump filter is blocked, or the drain pump may have foreign objects lodged in it making it unable to drain. All these issues can cause your LG washer to display the error code OE. With all these different reasons, checking all 3 components will clear the error and fix your LG washing machine.
Oct 29, 2017 | Washing Machines
LG front loading washing machine Direct Drive 7 3.5KG Trouble shooting Error OE
go to lg.com, enter your model number and manual will show error codes and fixed for some including OE
Aug 29, 2015 | LG Washing Machines
i have the error code OE showing up, and the water is not draining from the washer. What should I do?
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages. Clean out the trap from the bottom, something is jamming the drain motor.
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Jun 22, 2011 | LG WM-2277HW Front Load Washer
26,326 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
