When oven is on, power cuts off (no time display, no oven light, etc.) Indicator light on bake temp knob will sometimes flicker when turned, but won't stay on. happens intermittently- breaker is not tripped,
If neither
the bake nor the broiler heating elements heat, but the range burners
still work, the clock may be set for a timed or self-cleaning cycle.
Check to be sure the clock buttons and knobs are set properly. If your
clock has a knob that says "push for man(ual)", push the knob in and
try the baking and broiling elements again. If it still does not
operate properly, you probably have a defect in the thermostat,
selector switch, or common wiring.
If the oven does not have a
separate bake/broil/etc. selector switch, the problem may be with the
thermostat. But it's not easy to check the selector switch or
thermostat for proper operation. If you suspect a problem in this area,
call a qualified appliance repair technician.
The red key sign is a lock against children. To cancel it you have to hold the two buttons at the same time for 5 seconds (you activate it the same way).
The STOP sign appears after the cooker switches of after a power cut. You just have to press the left button, and, using the right knob, set the time.
make sure that the clock is displaying the current time of day
select timed bake
select the temp of the oven you wish to bake at
set the time you wish the oven to come on with the start knob
set the time you wich the oven to turn off with the stop knob
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
I have the digital timer oven and also cannot find the manual. You have to set the bake time timer, I think for 3 hours. Then you set the oven knob on clean and turn on the temp knob, probably to full but I don't think it matters. When you engage the lock, the clean light should come on/ When the oven reaches high temp, the lock light will also be on.
