Hi
Try resetting it - it worked for me. First, orient your watch face down (with the watch belt buckle opposite you), the new battery in and latched. Second, on the right side battery hold-down latch you will see a small metal circle (~1 mm diameter) with a black dot in the center. Take a small paper clip and touch this metal pad to the metal battery hold-down latch for about 1 second. This will reset the watch.
Rotate the tiny donut that clips over the battery so it touches the brass spring that is next to the battery, replace the back plate. you can use a small tool to carefully lift the metal contact back up off the contact plate. Also make sure the back of the case is on tight as this also plays a role the electro mechanics of this watch.
Let us know if you want to know something else accept the suggestion.
Thanks for contacting fixya.com
