Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
There was an issue with the 4000 series and the NiCd batteries I remember that had to do with the contacts in the camera. The charging circuit is in the camera so you have to make sure that the battery contacts are clean, both on the battery and in the camera.
Mine did that and all it was is the door that holds you batteries in gets weak over time. If you hold or squeeze the door closed and it does not happen then you have found you problem. Clean the contacts and try to "bend" them outward to get a cleaner and tighter connection.
Only by examining the camera your self will you find out
If you managed to purchase a part- perhaps an installation diagram is available from the same source.
