20 Most Recent Kodak EasyShare DX4530 Digital Camera Questions & Answers
2answers
Whenever we take a photo, there is a blie
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
11/15/2021 6:47:46 PM • Kodak EasyShare... • Answered on Nov 15, 2021
Computer all of the sudden won't recognize my camera...
Remove the media card from the camera, and use a USB card reader on the computer to access your images
3/11/2017 10:24:07 AM • Kodak EasyShare... • Answered on Mar 11, 2017
None of my memory cards work in my Easyshare DX 4530. The camera states that they need formated even the ones that have been used in it before.
Well, in that case, make sure you have backup of the images on them, then format them.
12/4/2016 10:38:18 PM • Kodak EasyShare... • Answered on Dec 04, 2016
2answers
I just inserted a 8
8MB or 8GB? If it's actually an 8MB card, you'll be able to put maybe two or three pictures on it, so I'll assume it's an 8GB card.
The DX4530 is designed to work with SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD devices, there are electronic difference that prevent them from working there. SD cards will work in SDHC devices but not the other way around.
You need to use SD cards, 2GB and smaller.
5/1/2016 8:13:31 PM • Kodak EasyShare... • Answered on May 01, 2016
My camera want work unless it is on the charger. i have new rechargeable batteries in it.
Get the battery tested it is not holding a charge.
2/24/2015 1:21:11 PM • Kodak EasyShare... • Answered on Feb 24, 2015
Help resetting memory card
Can you check if the Write protect swith is on on the SD card. It means as I understand, you have to reset the swith to inactive state.
11/26/2014 9:08:33 AM • Kodak EasyShare... • Answered on Nov 26, 2014
I have tried numerous times to charge two different Kodak batteries on two different chargers and they only hold the charge for 1-2 hours. The batteries never did this before and they are new. Could
Almost all easyshare (and Kodak cameras) eat batteries..... in my opinion, they're not worth the materials they're made from.
5/25/2014 4:46:13 AM • Kodak EasyShare... • Answered on May 25, 2014
0answers
0answers
My Kodak EasyShare DX4530 camera dock not charging batteries.
There was an issue with the 4000 series and the NiCd batteries I remember that had to do with the contacts in the camera.  The charging circuit is in the camera so you have to make sure that the battery contacts are clean, both on the battery and in the camera.
11/12/2013 3:08:41 PM • Kodak EasyShare... • Answered on Nov 12, 2013
0answers
2answers
My macbook air does not have an optical drive how can I get the soft ware for my kodak dx 4530 on my computer?
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
1/28/2013 12:28:39 AM • Kodak EasyShare... • Answered on Jan 28, 2013
Kodak EasyShare DX4530 Digital Camera Logo
128 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
camera want work unless charger new
  • Cameras
