I just bought an RV and the refrigerator has stopped working. I brought it home and set it up where it was level and it worked fine for a few weeks. I moved the RV and where it was parked it was not setting level and when I moved it back an leveled it the refrigerator would not work anymore. It is a Dometic RM280. The 110 heater and LP is working. Controls are working no cooling in the fridge. Could you please help. Thank you
SOURCE: norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
SOURCE: the freezer seems to be working fine but the
If you want a service manual for a Dometic Brand click on the link below. They are good people they will help you.
http://www.gasrefrigeration.net/dometic_manuals.htm
Aug 06, 2009- If I can help you let me know, I work and talk to Dometic a lot, Thanks Sea Breeze
[email protected]
SOURCE: I am new to the RV world. I have Dometic DM2652.
Yes, you can operate the fridge on propane while driving, instead of running the generator for electric operation. However, you should have a dual tank setup to prevent running out of propane.
Propane tanks with OPD valves aren't holding a true 20 lbs of LP, but rather only hold 17-18 lbs of LP. However, if you're swapping/exchanging your tanks instead of having them refilled, you're only getting 15 lbs of LP in the tanks these days, (check the label at the bottom of the tank to confirm). Hence the reason to have a dual tank setup on your RV to get longer run times.
I thought you might want to have a tech manual for your fridge, so here's a link to the Dometic site, you just need to select yours based on the manufacture date, etc.
http://www.dometicmanuals.com/UM/Dometic/MASTERDometic.nsf?Opendatabase
Hope you find this Very Helpful and best regards!
Testimonial: "Great info."
SOURCE: dometic 2600 rv fridge
UNPLUG AND TURN IT UPSIDE DOWN FOR A DAY OR TWO. YOU MIGHT HAVE AMONIA CRISTALS BUILT UP IN YOUR PIPES. TURN IT BACK AND SWITCH ON YOU GAS BURNER AGAIN. THIS WILL SOLVE YOUR PROBLEM. IF NOT, GET A TECHNICIAN TO CHECK IT OUT.
I meant RM2807
