THQ Company of Heroes for Windows Logo
Posted on Apr 22, 2010
I dont have a BsSndRpt.exe file, how do i get one and where do i put it ?
Dont have Webfetti.exe am i suppose to download
WEBFETTI.EXE According to the samples of WEBFETTI.EXE we received. We know WEBFETTI.EXE is a virus file. Now tell you what is WEBFETTI.EXE and how to remove WEBFETTI.EXE
WEBFETTI.EXE was found has the following beheavor:
Creates TCP port listens and communication initiated by other hacked computers
Infector file which modifies program files to include a copy of the infection
interrogate with security products in infected systems and resists
using FTP connections Communicates with other computers
The file process creates other processes in you desktop
I down loaded a HP Deskjet F4280 DRiver and I dont know how to put a short cut for the scanner
Open your Prgram files dirctory and open the folder for your scanner. Click the "View" on top bar and set it to "details". Listed there somewhere will be at least one, probably more, .exe files. Find the .exe file that opens the scanner ( look for SCAN in the name) open it to make sure it is the right file, then right click it and choose "create a shortcut" which will create a shortcut on your desktop. It is also possible in some configurations to get a "send to" option when you right click, where you can choose to put a shortcut somewhere else, possibly Quick Launch. There may also be a choice in the context menu to "add to startup" which will put a shortcut in your startup list.
2helpful
I dont know how to install the firmware for my mp4 i really need help
Do you have the CD for the SMPK8858 ?
Then put the CD into the CD drive or DVD drive of your computer and explore the CD, for the firmware update look under:
\Firmware Upgrade tool\ConsumerUpdate 3.1.2.0\setup.exe
1. explore or double click folder Firmware Upgrade tool
2. explore or double click folder ConsumerUpdate 3.1.2.0
3. run or double click file setup.exe: this will start the installation of the update software on your computer.
After the installation of the setup.exe file, run the firmware update program to start the update for your player.
Most Sylvania players will have a CD provided. When you don't have it, download the driver (a zip file) from Curtis:
http://www.curtisint.com/html/CustService/Manuals/SYL_SMPK8858_DRIVER.ZIP
After the download unzip the file with WinZip or WinRar:
now look for the firmware installation program under
SYL_SMPK8858_DRIVER \ SMPK8858 \ Firmware Upgrade tool\ConsumerUpdate 3.1.2.0 \ setup.exe
Double click the setup.exe, the same procedure as when using the CD.
There is also a manual for SPMK8858 (a pdf file) online:
http://www.curtisint.com/html/CustService/Manuals/SYL_SMPK8858_EN.PDF
What program should i use to open files they dont open with internet explorer
A file is usually open by the computer only when the associated program is installed in the system. The associated program recognize the file extension and open it.
For Example :A notepad file will be open by Notepad editor untill and unless you cange it to open with other program.
Microsoft Word can open a notepad file too.
Files usually you will find or will downloaded from internet are usually .exe, .rar, .zip, mp3, .avi, pdf etc.
I recommended, you installed these few softwares
1. Adobe Flash player.
http://fpdownload.adobe.com/get/flashplayer/current/install_flash_player.exe
2. Adobe Reader.
http://ardownload.adobe.com/pub/adobe/reader/win/9.x/9.2/enu/AdbeRdr920_en_US.exe
3.Jave runtime
http://fs4.filehippo.com/2222/75ce054974f24f4ca18bf8c0be7bc18f/jre-6u17-windows-i586-s.exe
4. Winrar
http://www.rarlab.com/rar/wrar391.exe
Don't if you are not sure of the application to open a file.Download
"Irfanview".below is the link
http://fileforum.betanews.com/sendfile/1099412658/1/1262777908.514057fe0774684918afa85f23fdb31b3a1511ce/irfanview_plugins_425_setup.exe
It will open almost any files.
That's it.
1helpful
3answers
Missing file: \windows\system32\winload.exe
Boot from your Operating System CD and do a Repair. This should solve your problem.
or
To fix this issue next time, boot Operating System, F8, select Command Prompt, type the following (anything inside the parens is a comment):
C: (assumes the C drive is the default)
CD Boot
Dir
(look to see if the BCD file is missing - it probably is.)
Bootrec /rebuildbcd
(Let the script run and it should rebuild the BCD and the issue should be resolved)
3helpful
2answers
Trojans wont go away. Hijackthis SCAN help
I am of the mind to do a complete reinstall of the operating system including flash the BIOS even if it is the same version. I worked many hours tracking down and thinking you found every part of the problem on to hit an .EXE and it all starts over again....I just clean out everything and start fresh.
If you tell us what make and model of computer along with the operating system it is we can direct you to the drivers for the reinstall. Some off those programs - for example AOL seem to be virus magnets. (if it is a dell it is really simple if you just put in your service code- it give you your particular driver of your computer.)
That is what I would do...Or you can keep hunting.
please leave rating,,,thank you
The .exe file for Acer Aspire 2920Z
go to acer.com, click on support and then drivers and downloads. put in your exact model and number and it will take you to the right spot for the drivers, just select the webcam drivers for your unit and download and install. let me know if you need more specific help.
I want to install a .exe file in windows moblie , but it says format not recognised. Is converting .exe to .cab a solution ? And how do i convert it .
hi there its bit time consuming.. try this link tinyurl or download pdf file from here Exe Installation on SmartPhones
hope it will help you... dont forget to get back about how did you go. thanks
5helpful
Konica minolta 1350w status display comes on at start up
Open c:\windows\system32
find a file called MSTMON_Q.EXE
right click and rename the file to anything with a file extension .exe, I named it MSTMON.EXE
Create a shortcut to this new file in case you need it in the future and put the shortcut on your desktop
also, write the original name of the file down or put it on notepad, in case you want to change it back.
restart windows
Why you given exe file to install Lexmark printer driver??
Yes this is driver file u need...exe just double click it...
Top THQ Video Game Consoles & Games Experts
ZJ Limited
ZJ Limited
MegaByteMe
MegaByteMe
Mark Ultra
Are you a THQ Video Game Console and Game Expert? Answer questions, earn points and help others
