Washing Machines Logo
Posted on Apr 21, 2010
The door on my Bosch washing machine 1605 is stuck on shut
The door on my Bosch washing machine 1605 is stuck. I have turned it off and waited and then tried to open the door pressing the button and nothing - jammed shut with my washing inside... what to do?
Anonymous
Level 1:
Scholar:
  • Contributor 39 Answers
  • Posted on Apr 22, 2010
Anonymous
Contributor
Level 1:
Scholar:
Answers
39
Questions
0
Helped
21483
Points
74
Hiya,
the door not opening is normally a sign that there is still water inside if you can try a spin cycle or if you have a drain option try using that & if it was the water then the switch will trip & you should be able to open the door again.
Hope this helps
Bosch nexxt inspiration
You may have blockage-clean your drain trap-if this doesn't help you may have a plugged hose or something stuck in the pump-cheers Denny
Opening the door after a wash
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start / pause light flashes.
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped.
The washing machine door won't open
Has it been stuck? Check the screws that holds the washer door. If the metal parts have corroded, the door probably is stuck. You might have to lubricate the metal parts to loosen it up.
It might also be caused by a broken door switch. You might have accidentally slammed it shut and now it won't open up. Pry it gently but you might need to replace the switch.
source: http://www.washingmachineadvisor.com
Bosch Classixx will not start
Just a guess, but it sounds as if the machine doesn't think the door is shut. Try pushing against it as you turn it on, if that works, then I'd guess there's a door shut switch that needs adjusting.
NOTE. This reply is from an amateur guesser who knows nothing.
My Bosch WFF 2000 washing machine goes through its cycle and then leaves the on/off button lit, the door button lit and the pre-wash button flashing; also the door will not open until you turn all the...
The problem turned out to be foreign objects in the pump that stopped the machine from draining; the solution is simply to open up the pump and remove the objects!
2answers
Bosch WFB 1605 washing machine
i am so upset with my fancy $1100 plus washer that doesn't work that my husband wants to cart it to the dump
Top Washing Machines Experts
john h
