You can't. You can get a basic RCA/GE remote at Walmart or HomeDepot for $5.
u can use a universal remote. get it programmed n the menu pulled up remove and replace a battery and the channel and volume buttons should work the menu. just had the same problem and this is how i fixed it. i even programmed the remote to work the tv with the universal with the fpa block on. when u get the menu pulled up the light will flash and thats when u need to remove and replace the battery, the light with stop flashing and the up and down keys worked. good luck this worked for me...
