I have four dell optiplex gx620 computers. Three have suddenly dropped off showing no signs of power though they are plugged in. I mean no lights, no fan, no signs of power. Do you know if this is a common problem and if so ... what is the likely failure ... Power Supply?
First check your power supply at the outlet. If that is okay, check that the power is turned on at the back of the cpu. If still no power check the power cord. This part should be easy since you have a computer that still works. Just switch the power cords. It does sound odd since all three stopped at the same time. But if they all run off the same circuit you could have a bad fuse or tripped breaker.
Yes take it up to the place u bought form and say yall broke my stuff
I may have given you the wrong idea. They dropped off one at a time. Each are connected to UPS's which show an output on meter of Normal voltage.
