You have to find one of two ways to remove the upper part of the machine.First, unplug the machine from the power source on the wall.By the upper part , I mean the lid of the drum. The first way is to check the back of the machine for a plate cover that is taller than the lid and cover of machine. If that plate is present then that plate has to be removed. If not , then go to the front of the machine and with a large flat head screw driver insert from the front on each corner and pry the lid up . you will see various styles of clips that hold the drum lid down and you will use the screw drivvito relase the lid . From there you should be able to remove the debris. To re-assemble simply drop the lid and re-secure the drum lid by pushing down on the front.
